Do I need a different wifi dongle to connect wirelessly to fibre-optic
Old 15-08-2012, 9:32 AM   #1
YNWA1892's Avatar
Thanks: Gave 2,839, Got 1,049
I have recently upgraded to fibre optic due to having only 0.4mb broadband speed where I lived, since I did this I cannot connect my daughters base unit upstairs using the old wireless USB dongle.
Do I need a different type of dongle to do this now that I am using fibre optic, I wouldn't have thought I did as all the laptops and phones still connect by just putting the new router key in.
Any help would be appreciated
Old 15-08-2012, 10:03 AM   #2
Thanks: Gave 86, Got 810
No. The mechnism used to deliver broadband to your premise has no affect on the local wi-fi (or ethernet) infrastructure. They are all separate from each other.
It's possible that the new router (?) you got with your new service delivers wi-fi that's incompatible with your dongle, but that's somewhat unlikely.
Check that your wi-fi dongle and your new router offer some form of wi-fi that's mutually compatible. For example, if your dongle is "B" only compatible, and your router doesn't support "B" (or has it disabled) you wouldn't get a link.
YNWA1892 (15-08-2012)
Old 15-08-2012, 10:04 AM   #3
YNWA1892's Avatar
Thanks, i'll check this when I get home.
I thought it would be fine but wanted to check.
