Sorry i havent been able to reply until now
Originally Posted by electro Do you understand split level though? Do you realise the significance and how it works? Naming convention of folders/files, and a combination of split level and another setting (I forget the name) which defines how each disk is filled up, can massively influence how well it works for you. A lot of people will want to be able to watch TV episodes/series or browse pictures or other media without an additional disk spinning up. Each user share can be tailored to meet your expected usage. Storing video files inside their own folder is usually advantageous from what I have seen and allows for much more flexibility regarding split level. |
Im pretty certain my Unraid server only spins up two disks when something is requested - 1st the disk the file (usually a movie) is located on, and 2ndly the parity disk (Im guessing this is spun up for everyone in everyday use, I admit I should have checked this is normal activity, but never struck me as unusual either lol)
No other disk has ever spun up unless Im writing to the server at the same time, and this is without any use of split level on my part. Admittedly there has only ever been one user, but I have often tested my network by streaming more than one movie simultaneously, with no irrelevant disks spinning up.
Originally Posted by electro Because you might want to override where unraid deems it fit to distribute your files. Some people might use unraid server not just as media storage, but as a file server for documents and other backups of files/software. You might for example, want to store software which contains several subfolders of which you would want to ensure all reside on the same disk, so as when called upon, only one disk spins up to serve what you want. Not to mention that distributing something like software files accross multiple disks will introduce the latency of each additional disk that needs to be span up during say an install.
I'm just saying, these are the kinds of things that are holding me back as I keep trying to plan for my usage. Perhaps I am over analyzing somewhat.
For people that do not care for powersaving and have all disks spun up all the time they may not notice these things. |
I think this was answered above - maybe I fluked it during unRaid setup, but I dont believe I did anything additional to cause the above behaviour.
While I admit majority of my folders only contain a single file, so this is hardly ever going to effect me personally - I would also point out that majority of the users here are more than likely using any server for media purposes as the primary reason (and taking up majority of space)
I can see why anyone would want to keep series together on the same disc (for mass disc failure reasons if nothing else), but liklihood of this happening imo is remote. single disc failure is catered for by the parity drive - so its irrelevant anyway (apart from easing your mind lol)
Admittedly music is a whole different ball game and would be more likely users requiring this......but good luck finding more htan the occasional person/family to have over 1000 CD /vinyl albums for multiple disks to be a concern lol . (maybe not obviously but I would say at this point its likely with a mixed media server to have different root shares - ie Movies, Photos, Music - all on seperate shares rather than mixed together)
Originally Posted by electro I'm not thinking about it from that angle. More that I do not want people to be browsing shares that have modify access incase of accidental deletion of content. I am wondering how people manage this. i.e. Say I want to be able to write to/modify the share, then I would look to setup a password for this to be allowed. For all media shares I would allow read access to anybody, so clients that are just media players should have no issues. |
Thats a very good point, which being the single user of my server I hadnt really considered.
Originally Posted by electro Yes. I do quite agree. Most uses of unraid should only really require very basic read requirements. However, I would personally be looking for as high a read/write performance as possible since I plan to use it as a general file server as well. I gather than NFS shares are best for performance, but I am not sure if they can be a pain to setup with stability. I probably will run a cache drive and I may explore an Intel NIC. The onboard realtek NICs have been blamed before for being a large bottleneck.
Hugo, how long have you had your setup? Any extra info on your uses, hardware, setup most welcome. |
While I appreciate your interest in using it for general purpose filing also - these files are going to be (more often than not) of tin file size are they not, so is transfer speed really going to be an issue?
If you are meaning large dumps of software installs etc, I would either investigate just doing licence documentation etc with hard copy cd burns of the actual disc
Otherwise I cant really assist with your NFS queries
Ive had my server for about a year or so, while I have built many windows machines in the past (back to Win NT 4.0 and Win 3/Dos) this was the first server I built of my own. 90% of which is BR movie rips. Mainly streamed to a pch but occasionally to a Win 7 laptop
