psikey
Outstanding Member
Decided not to do a separate thread and just post the photos with comments in here:
All my bits ready
Did change the fan for an Ultra Silent Akasa but had to take back out as different connector/wiring
Power splitter cable (only had 1 molex to 2 SATA so need to get 1 to 3 SATA
The little RocketRAID card from a WD 3TB drive pack I bought a while ago. Had to trim off bottom of bracket.
Extra SATA cabled routed to back and two 2.5" Samsung 320GB drives attached with sponge double sided sticky pads to DVD drive.
Did make a bootable USB of Windows Home Server 2011 so I could disconnect the DVD and power both 2.5" drives until I get the 1-3 power splitter.
System configures as RAID1 for OS using 2 x 320GB 2.5" Toshiba drives and RAID5 for Media Storage using 4 x 2TB 3.5" WD RE4-GP drives
Will do the Acronis Image of the OS tonight before I start messing around with configuring & installing stuff so I can quickly get back to my starting point.
I used the Shift-F10 trick to get the Workgroup name changed to KEYNET which my network uses. Not necessary but wanted in showing KEYNET not WORKGROUP.
Once I get the rebate back I'll have only spent £139 as everything else I had already (had drives from the QNAP I sold). Added a 4GB RAM to the existing 1GB for 5GB total which should be more than enough!
All my bits ready
