jameson_uk
Am I right in thinking that the free unRAID version only supports three data drives?
Feature Basic Plus Pro
Maximum Array Width 3 6 21
Cache Drive supported No Yes Yes
User Level Security (see note) No Yes Yes
Active Directory No No Yes
For info the the memory is made by Hynix HMT112U7BFR8C-H9 it is DDR 3 & is unbuffered but REGISTERED I've read that this server will also take unregistered DIMM's provided you do not mix.
[/URL]
Hi Tim,
I'm also going down this route as i've been put off by the price of Synology and QNAP, plus the opportunity to tinker is always good.
Re the memory, i've read similar regarding the unregistered modules, does that mean i can install something along these lines: -
Kingston Memory Modules
Have you thought any more about your cache drive, or not that fussed?
Cheers, Dan
Are crescent an HP authorised reseller (in other words, have you got your rebate ok?!)
Tempted myself.....
Hmm, cresent not such a great deal when you find out "free delivery" is only 7 day delivery, and they add 1.5% to your credit card bill! Still, slightly cheaper than eBuyer that was other option at £139 free 5 day delivery.
Can you imagine a storage cluster made of a few of these, optionally with another 1Gbps NIC (or even a dual-port Gbps NIC)? Mmm, tasty! I'm not helping your restraint, am I?
Jeez...mate you're so lucky, phew
Please can you confirm everythings flashed ok does the BIOS look like mine now?
Tim.
