Siemens Gigaset SE572
Old 30-07-2009, 9:16 PM   #1
I don't know if this is the right place to post this but I have an old Siemens Gigaset SE572 Router which I got when I was with Orange Broadband and I no longer use it. I was looking to know if this old orange router could be used as a broadband router for other ISP'S.
Basically what I am wanting to know is I am thinking about switching to ADSL24 for my broadband. They do not supply a router and I want to know if I can use this old router for my broadband without having to buy a new router. If I can, does anybody know what I would have to do to configure it to work with another broadband provider.
Thanks in advance for your help.
Old 31-07-2009, 9:01 AM   #2
Thanks: Gave 21, Got 755
Re: Siemens Gigaset SE572
The only thing that can stop your using it is if you can't change the User Name/Password. Go into tht setup and see of that can be done. Then, when you get your ADSL24 User Name/Password, enter them and Bob's your uncle.
Old 01-08-2009, 9:44 AM   #3
Thanks Beerhunter for your reply.
I have checked the settings and yes I can change the username and password. There were alot of other settings which I thought might had to be changed.
Also as I said, I got the router directly from Orange. They have their branding logo stamped on the router and when I access the settings for the router Orange have their logo on the settings as well. Because of this I just wanted to check that I could reuse the router with other broadband providers. I thought that Orange may have programmed or locked the router in some way that it can only be used for their broadband service.
Old 01-08-2009, 11:36 AM   #4
If you can change the User Name/Password that should not be a problem.
Old 01-08-2009, 1:19 PM   #5
Thanks Beerhunter
You just saved me the cost of buying a new router.
