| Re: TASCAM 788 - How to connect mixing desk to pc
Hi by the looks of it that desk is a self contained unit with a hard drive so you should be able to record and edit within the unit itself.
What advantages are you hoping for by connecting to a PC?
Presuming it hasn't got a USB port probably the best way would be to connect it via audio so you'll need an audio interface of some sort. However you'll lose the multitrack granularity so for example you won't be able to mix the levels as you would be able to do within the machine itself.
