Having had my gear living in boxes for a while, I decided to get it all out and to start playing/recording again. Only trouble is, I'm not sure of the best way to wire it all up for MIDI and audio.
The kit that I have is as follows:
x1 Keystation Midi Controller (USB Midi + Midi In/Out/Thru)
x1 Yamaha MM6 Synth (USB In/Out + Midi In/Out)
x1 Roland D10 Synth (Midi In/Out/Thru)
x1 Edirol UA-4FX (USB + Midi In/Out)
Behringer 12 Channel Mixing Desk - Audio only, no USB or FireWire connections.
PC with EMU 4404(?) Soundcard - Midi In/Out + Audio In/Out
Various DAWS including Cubase LE, Sonar LE and MixCraft 4.
If anyone out there can give me a basic idea of how to wire this all up correctly it would be great. For example, should I MIDI the Keystation to the Roland to the Yamana to the Edirol to the PC, or should I link the Keystation to the PC via USB, PC to Yamaha via USB, PC to Edirol via USB, PC to Roland via MIDI.
Should the audio outputs from the instruments go to the Mixer - into PC via EMU 4404 - PC to Edirol - Edirol to amp/speakers? Or should I use the Edirol as an AUX send from the mixing desk?
Do I need any other kit to get this to work or does what I have pretty much cover most eventuality? I have been looking at mixers with USB/Firewire connectivity - should I get one of these if it will make things easier? I am thinking also of getting an FX box that I could use for reverb, echo etc - although I do have a couple of guitar pedals with this functionality - could these be used as AUX sends from the mixing desk?
It was so much easier when I started all those years ago - 4 track Portastudios and no DAW's!
Any help and suggestions are more than welcome.
Cheers,
Iain
