Originally Posted by Geege I'm getting into playing electric guitar again after 3 years. I've decided what guitar to get, it is just the amp I'm thinking about now.
I live in a terraced house with a young family so intend to play at low levels and with headphones. Money is not really important so my budget is flexible. - 30 watts or less
- Must have headphone input jack
- Good sound for rock & metal
- Range of digital modelling with be nice, although happy to invest in a Line 6 POD or effects pedals if need be.
- Must sound good at low volume levels, (2-3)
- Having a footswitch option would be good too
Some I have considered both in the 15 watt and 30 watt versions:
Marshall MG DFX series
Line 6 Spider series
Peavy Vyrper series |
I can only comment on what I have got but I bought recently (as it seems I am in a position similar to yourself, house & family & picking up playing after a long break) a VOX Valvetronix AD30VT-XL. It was between this and a cube for me at the time I bought it.
I made the purchase based on the following:
1 - The sound, I really liked the tone vs the more digital sound of the cube.
2 - It had to be able to sound good for metal & shredding even without footpedals.
3 - Had to sound good at low levels. This model has a dial at the back of the unit which effectively kills the watts which allows you to drive the amp but and keep the sound (and works for the most part).
4 - Needed a few effects, nice clean sound & as well as crunchy sounds. I am not too bothered for effects although it has quite a few.
5 - Needed to be cheapish as our lass was buying it for me as a present.
I have had the amp for 6 months approx at a guess and I am happy with it overall for the money.
I have played around with it and messed with the effects but only really use 2settings which is distorted setting & a clean one every now and then (so not often) found in the end I didn't like the results of the other settings for my personal taste.
I like to have a nice smooth tone as well as chucky bottom end for lead work which this can do quite well (at the price point £130ish) and also chucky riffing which it can do. I use the amp straight with no pedals although I have tried a boss DS1 & MZ2 with GE7 and still found best results came from the amp without.
If money wasn't an option I would have shopped around some more but can say that the VOX does what I want well enough and I don't do the band think any more so that was not really considered.
I play mostly at night but I have found that when I have driven the sound (30watts) the sound changed at high volumes from what I have set it at and had to mess around to get a sound I liked again. This isn't an issue though for me as stated with the band thing and as I play on an evening with everyone in bed.
I think it is discontinued now but I have seen them on ebay going from £50 upwards. I don't think they were hugely successful. Plenty of clips on you tube for ideas of sounds. Has option for footswitch & headphones also (need to check the later never used any).
Info:
http://www.voxamps.com/downloads/PDF/AD_VTXL_OM_E1.pdf
User review:
AD30VT-XL Review | Vox | Guitar Amplifiers | Reviews @ Ultimate-Guitar.Com
Hope this helps.
eatstatic
