3.5 million visitors each month
Go Back   AVForums.com > Movies, TV Programmes and Music > Movies and TV Shows On Disc and Downloaded
Latest AVForums Movie Reviews
Zombieland Blu-ray ReviewLast King of Scotland, The Blu-ray ReviewAfrican Queen, The Blu-ray ReviewCirque du Freak: The Vampire's Assistant Blu-ray ReviewToy Story Blu-ray Review
Clash Of The Titans Blu-ray ReviewVengeance Blu-ray ReviewHellboy Animated: Sword Of Storms/Blood and Iron Blu-ray ReviewThe Andromeda Strain - Motion Picture Soundtrack CD ReviewMulan Blu-ray Review
Thread Thread Starter Forum Replies Last Post
Can USA NTSC camcorder export from Japanese NTSC MiniDV tape? ricktherazor Camcorders and Video Editing 1 13-09-2007 6:27 AM
Which 36" TV? NTSC only prog scan or both NTSC and PAL? GavinH CRT TVs 1 23-09-2003 1:09 PM
E-30 : Wiring up Machines, slight ghost and NTSC to NTSC copies. Mark Bennett DVD Players 0 11-04-2003 3:25 AM
Old 07-04-2008, 12:46 PM   #1 (permalink)
sizedoesmatter's Avatar
Thanks: Gave 13, Got 21
Blu Ray PAL v NTSC
In the "old day" of region 1 & 2 & NTSC & PAL there was a distinct difference in picture quality.
Has that gone now in the 1080i/p options that Blu-ray brings?
sizedoesmatter is offline   Reply With Quote
Old 07-04-2008, 1:55 PM   #2 (permalink)
Conspicuous Member
Pecker's Avatar
Thanks: Gave 1,736, Got 1,208
Re: Blu Ray PAL v NTSC
Largely, yes.
Almost all Blu-ray Disc releases use identical 1080p transfers for both the US & UK versions.
There are odd exceptions, where the distribution rights are held by different studios in different territories, but even then the transfers are often the same.
And when the transfers are different the chances of either the UK or US version being superior are 50:50.
Finally, when there are differences (UK vs US Pan's Labyrinth or UK vs US Face/Off) the differences are pretty small, though you might then want to check out the situation with extras and soundtrack formats.
Just remember to watch out for regional coding if you import discs, or warranty problems if you import a player.
Steve W
Pecker is offline   Reply With Quote
sizedoesmatter (07-04-2008)
Old 07-04-2008, 2:37 PM   #3 (permalink)
wastedyuthe's Avatar
Thanks: Gave 51, Got 24
It's not too important, but I like the fact that we are now (for the first time with UK disks anyway) getting the films at the correct speed, which means having the original running time (instead of a difference of 4 mins for a feature length film) and correct sound pitch (not that I myself would ever notice).
Pioneer PDP-4280XD, Panasonic DMP-BD30, Logitech 785 remote, Nintendo Wii, Apple Macbook Pro, iPod Touch 32gb, Humax Foxsat PVR
wastedyuthe is offline   Reply With Quote
Old 07-04-2008, 3:23 PM   #4 (permalink)
Thanks: Gave 12, Got 5
The different pitch is especially noticeable on music I find. I bought the R1 release of Sopranos season 1 a few years ago and the title music sounded very weird and slow after having been used to the Channel 4 broadcasts.
Joe.
Joe Sueiras is offline   Reply With Quote
Old 07-04-2008, 3:26 PM   #5 (permalink)
Incidentally, have there been any 50Hz Blu-Ray or HD-DVD releases? As I understand it, even the recent BBC releases (titles like Robin Hood) were 50Hz to 60Hz standards conversions.
Joe.
Old 07-04-2008, 3:57 PM   #6 (permalink)
Thanks: Gave 2, Got 24
I thought all Blu-Ray discs were identical asfar as Hz is concerned?
Aren't they all 1080/24p and it's just down to the player / TV to handle it?
Arthur Hucksake is offline   Reply With Quote
Old 07-04-2008, 4:33 PM   #7 (permalink)
As well as the aforementioned BBC releases, I think some music titles are 1080i at 60Hz. There's also the infamous error on the Terminator 3 blu-ray, which was encoded at 1080i.
I don't believe there have been any 50Hz releases, although that would be the native format for titles such as Robin Hood and Torchwood. Possibly Planet Earth as well, but not so sure about that one.
Joe.
Old 07-04-2008, 5:01 PM   #8 (permalink)
Thanks: Gave 859, Got 1,194
The vast majority are 1080@24 on the disc but this still does not mean they are the same. We have three different video codecs (which can make a difference) and then there are also versions at different bit rates (even using the same codec), and finally post processing like filtering / edge enhancement. Having said all that, the only things we have really seen in any numbers have been MPEG2 (which even at high bit rates I think is behind AVC / VC1) and a touch of filtering / edge enhancement. Only MPEG2 really bothers me tbh and the vast majority of people just don't have the kit or room to even see these differences anyway. Things are much better than the early days of PAL and NTSC.
Do everything with excess, even excess
Nic Rhodes is offline   Reply With Quote
Old 07-04-2008, 5:20 PM   #9 (permalink)
Thanks: Gave 853, Got 599
He mentioned it ..... but I think he got away with it ....
KeanosMagicHat is offline   Reply With Quote
Old 07-04-2008, 5:54 PM   #10 (permalink)
Can someone explain the picture quality differences between PAL and NTSC on DVD? PAL format had a higher vertical resolution, right? So in wide screen films, would this mean that just more black space was added to the image? Not so advantageous.
As for BD in region b vs a, I'm pretty sure that the Tiesto BD is encoded at 50hz, which means that it will not play on American HDTVs cos the televisions only support 60hz. I'm not sure if it will play on the 120hz sets though. Does anyone know? This doesn't apply to HDTVs in UK and Europe of course.
Which BDs out there are encoded at 50hz?
djepic112 is offline   Reply With Quote
Old 07-04-2008, 6:30 PM   #11 (permalink)
Not so. Basically, if you watch an NTSC version of a 2.35:1 ratio film for example next to a PAL version, the black bars will take up the same amount of space on your screen on both. The only difference image-wise is that PAL, as you say, is made up of more lines, so you actually get sharper detail with PAL.
In fact, if an NTSC widescreen version of a film is non-anamorphic (so you have to change your tv display to zoom in), the difference is even more noticeable, and on larger sets, a zoomed in NTSC DVD can look so blocky it is, in my opinion, almost unwatchable.
Old 08-04-2008, 6:58 AM   #12 (permalink)
lgans316's Avatar
Thanks: Gave 286, Got 425
Some of your understanding is incorrect. Though the main feature (movie) has nothing to do with PAL/NTSC there is a possibility of the special features to be PAL/NTSC formatted. For ex, the bonus contents on U.K Pan's Labyrinth and Dutch 1408 was PAL formatted @576i/p or at 50 Hz which didn't play at all on U.S / Japan NTSC only BD players.
Blu-ray : 215 + [2]
lgans316 is offline   Reply With Quote
Old 08-04-2008, 7:10 AM   #13 (permalink)
Thanks: Gave 7, Got 17
Originally Posted by lgans316 View Post
Some of your understanding is incorrect. Though the main feature (movie) has nothing to do with PAL/NTSC there is a possibility of the special features to be PAL/NTSC formatted. For ex, the bonus contents on U.K Pan's Labyrinth and Dutch 1408 was PAL formatted @576i/p which didn't play at all on U.S / Japan NTSC only BD players.
I wanted to reply the same thing: SD extra's can be a problem on a player from a country where they have NTSC (US/Japan).
TAG AV32Rbp-192 dp 7.1, Emotiva MPS-1, Arcam DV27a, SB2, MPX550, DEQ2496, LCR=3xCatalyst, surrounds=4xRS850, subs=2xSubMersive;
JVC DLA-HD1 + Toshiba XE-1 + US/EU PS3 + Panasonic BD55;
182 HD-DVD's + 775 Blu-Ray's (Region A/B = 99/49) of which 5 titles ordered/underway.
Ettepet is offline   Reply With Quote
Old 08-04-2008, 7:39 AM   #14 (permalink)
Thanks: Gave 33, Got 77
There is no such thing as PAL and NTSC for high-definition formats as those refer to interlaced formats, eg. 480i/576i.
HD movie discs display in progressive scan at 60Hz regardless of whether they're from Europe or the US. Of course, some BDs and HD DVDs run at 1080i, which is technically an interlaced format, but the HDTV converts and displays it either at 1920x1080 or downscaled to its native resolution anyway. HDTVs don't actually show interlaced images like on CRT TVs (where there's visible flicker) as their screens are progressive scan only (just like PC TFT/LCD monitors).
In my own experience, movies tend to play at 1080p and special features sometimes at 1080p, but more often at 1080i or 480p even on UK discs, I've not watched anything that's been 576p for example.
Core i7 920 @ 3.36 GHz | ASUS P6T Deluxe motherboard | 6 GB DDR3 1600 MHz memory | EVGA GeForce GTX 280 graphics | 24" HP LP2475w monitor @ 1920x1200 | Creative X-Fi XtremeGamer audio | 128 GB Crucial SSD + 2 GB SATAII hard drives | Windows 7 Home Premium (64-bit)
Doctor Hades is offline   Reply With Quote
Old 08-04-2008, 8:17 AM   #15 (permalink)
^ You don't have it all right. Did you read the posts in this thread? There are many special features on EU BD's that will not play on US PS3 or BD players because the format is still in PAL SD. It's all on the HD BD disc but there are still PAL SD material.
Also, there is a least one BD encoded at 50hz (Tiesto's concert) and that will not work on the US PS3 (at least with US HDTV's, I'm not sure if the region A PS3 will still output the 50hz or not allow it at all- like with PAL SD features).
blu, ntsc, pal, ray
Copyright © 2000-2010 M2N E. & O. E.
