05-04-2009, 5:16 PM
#1 (permalink)
| | Veteran Member
Thanks: Gave 1,116, Got 193 | I use dvd profiler and would like a barcode scanner to use with it....  HELP!!!!
Not even sure if this is the right place to post and it's software, and hardware, but movie related
As title
I'm looking to buy a cheap barcode scanner that works with dvd profiler via USB.
I have no idea what to look for or where to start, I would be greatful if someone can point me towards a few to compare
thanks
tris
__________________ MY DVD COLLECTION "So let me get this straight, you want to fly on your magic carpet, to see the King of the potato people,to plead with him for your freedom, and your telling me your completely sane?!?!?!" |
05-04-2009, 5:54 PM
#2 (permalink)
| | Senior Member
Thanks: Gave 110, Got 84 | Re: I use dvd profiler and would like a barcode scanner to use with it....
hi mate - i have dvdpedia and scan using the built in icam. not sure if profiler allows you to do so. although i find manually searching is quicker.
05-04-2009, 6:04 PM
#3 (permalink)
| | Veteran Member
Thanks: Gave 1,116, Got 193 | Re: I use dvd profiler and would like a barcode scanner to use with it.... Quote:
Originally Posted by dannydj hi mate - i have dvdpedia and scan using the built in icam. not sure if profiler allows you to do so. although i find manually searching is quicker. | I have just heard (or rather read) that dvd profiler can be used with a barcode scanner.
I have sold a lot of discs lately, and bought quite a few blu rays.
The Problem is, I have gotten lost in the losts, so I want to be lazy and just scan the code with a lazer zapper thingy, as I also mke a typed list of each individual dvd/bd and really dont want to have to type out all the bar codes as well as theres a few hundred
tris
05-04-2009, 6:18 PM
#4 (permalink)
| | Veteran Member
Would somthing like this work with DVD profiler?? barcode scanner custom sd313e ps/2 on eBay, also, Barcode Scanners, Input Devices, Computing (end time 06-Apr-09 15:21:45 BST)
Just wondered if there is anyone else out there that has done this using dvdprofiler and can advise, on how and what to do
tris
05-04-2009, 6:28 PM
#5 (permalink)
| | Prominent Member
Thanks: Gave 94, Got 182 | Re: I use dvd profiler and would like a barcode scanner to use with it....
Years ago you used to be able to get a Cuecat, I think it was called for no more than a couple of quid on eBay, you had to do something minor with the software to get it to work with DVD profiler, was a 2 minute job and after that it worked fine.
No idea if you can still get them though.
06-04-2009, 9:29 AM
#6 (permalink)
| | Veteran Member
Originally Posted by Goooner Years ago you used to be able to get a Cuecat, I think it was called for no more than a couple of quid on eBay, you had to do something minor with the software to get it to work with DVD profiler, was a 2 minute job and after that it worked fine.
No idea if you can still get them though. | Seems the cuecat is about £13 on ebay now and has to come from the USA
Is there anything else anyone has tried that works for less than £20 that they can point me to??
(pref usb, but doesnt matter)
tris
16-04-2009, 11:55 AM
#7 (permalink)
| | Prominent Member
Thanks: Gave 95, Got 75 | Re: I use dvd profiler and would like a barcode scanner to use with it....
Any barcode scanner than can read standard EAN commercial barcodes should work.
There's northing magical about them or the application, the scanner becomes merely an input device which you could scan into anything, i.e. Notepad, Word, XL etc
20-04-2009, 6:40 PM
#8 (permalink)
| | Veteran Member
Originally Posted by Kevo Any barcode scanner than can read standard EAN commercial barcodes should work.
There's northing magical about them or the application, the scanner becomes merely an input device which you could scan into anything, i.e. Notepad, Word, XL etc | Thanks for that, although I ended up doing it manually in the end
I'll definately have to find one for next time, it would be so much quicker
tris
