23-12-2008, 10:57 PM
#1 (permalink)
| | Senior Member
Thanks: Gave 32, Got 82 | Question On Some HD-DVD's
Since I cant locate any HD-DVD sections here ill post here.
I was wondering if anyone knows if any of the following are on double sided discs.
16 Blocks
40yr Old Virgin
Dantes Peak
Daylight
Doom
Firewall
Holiday
No Reservations
Superman Films (Including Returns)
Transformers
Tremors
Stardust
Van Helsing
Serenity
Aeon Flux
Shooter
The Game
Hot Fuzz
Constantine
Terminator Films
The Lake House
Accepted
Mercury Rising
Assault on Precinct 13
The Mummy Films
Sahara
The Rundown
Canon 400D With Stock Lens.
Asus A8N-SLI Deluxe, AMD Athlon 64 3500+ (Venice Core), 2GB Corsair XMS Memory (2x1GB), Leadtek Geforce 7800GTX, Sound Blaster Audigy 2.
23-12-2008, 11:19 PM
#2 (permalink)
| | Distinguished Member
Thanks: Gave 18, Got 756 | Re: Question On Some HD-DVD's
Depends on where you buy the disc as I dont think more than a handfull of films were released in the UK as combo's but they were quite common in the US.
Off the top of my head I know that Superman Returns was released in the US as a combo.
Sony 40V3000 / Sony STRDG910 / UK XBox 360 Elite / Panasonic BD-35 (Multi-region DVD & BD) / HD-DVD & BD Media Centre
25-12-2008, 2:42 PM
#3 (permalink)
| | Senior Member
Thanks: Gave 32, Got 82 | Re: Question On Some HD-DVD's
Is this double sided ? It doesnt really say hmv.com: Transformers: 2hdd (2007)
25-12-2008, 7:28 PM
#4 (permalink)
| | Conspicuous Member
Thanks: Gave 294, Got 420 | Re: Question On Some HD-DVD's Quote:
Originally Posted by Indiana Jones Depends on where you buy the disc as I dont think more than a handfull of films were released in the UK as combo's but they were quite common in the US.
Off the top of my head I know that Superman Returns was released in the US as a combo. | The UK Superman Returns was single sided. I have combo UK discs of Smokin' Aces and Star Trek Season 1. I think series 1 of the BBC Robin Hood was a combo as well. I also have the US Children Of Men as a combo and my player doesn't like it.
Bri
25-12-2008, 10:44 PM
#5 (permalink)
| | Senior Member
Thanks: Gave 49, Got 81 | Re: Question On Some HD-DVD's
US versions of 16 Blocks, Superman Returns, Firewall, Hot Fuzz, The Lake House, No Reservations and Accepted were combos. The others were always single sided AFAIK.
As said above, combos were a rarity over here (TV boxsets excepted), so if you find a UK version of the above discs then they should be single sided.
26-12-2008, 12:08 PM
#6 (permalink)
Thanks: Gave 18, Got 756 | Re: Question On Some HD-DVD's Quote:
26-12-2008, 4:19 PM
#7 (permalink)
| | Senior Member
Thanks: Gave 32, Got 82 | Re: Question On Some HD-DVD's Quote:
Originally Posted by Geoff_D US versions of 16 Blocks, Superman Returns, Firewall, Hot Fuzz, The Lake House, No Reservations and Accepted were combos. The others were always single sided AFAIK.
As said above, combos were a rarity over here (TV boxsets excepted), so if you find a UK version of the above discs then they should be single sided. | ah thanks a million mate, I hate having to treat discs like they are portable nukes when handling them. Are they specifically labeled Combo or something else to identify them or is it just pot luck ?
I did start collecting the A-Team discs and Knightriders but then I got a version that was double sided and have been scared to purchase anymore seasons.
