Go Back   AVForums.com > Movies, TV Programmes and Music > Movies and TV Programmes On Disc and Downloaded
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 02-07-2008, 4:46 PM   #1 (permalink)
dannydj's Avatar
Thanks: Gave 109, Got 83
the fog hd dvd - anybody own it ??
is this worth the upgrade from sd dvd ?? as the reviews i have read are not exactly glowing ...............any feedback would be great - cheers
dannydj is offline   Reply With Quote
Old 02-07-2008, 5:42 PM   #2 (permalink)
digriz666's Avatar
Thanks: Gave 15, Got 30
Re: the fog hd dvd - anybody own it ??
Hi ya,
Its not the best hd dvd i have seen, some bits are quite good and a lot of bits are quite poor slightly more colourfull and a bit more depth.
If you can buy it cheap then why not!!!!!
Hope that helps
cheers steve
Its ups and downs ups and downs!
digriz666 is offline   Reply With Quote
Old 03-07-2008, 6:45 PM   #3 (permalink)
Thanks: Gave 34, Got 31
I think it is worth owning the picture quality is pretty good and have to say i wasn't at all dissappointed in buying it, then again I'm a big early Carpenter fan so would buy it regardless of the reviews, if you can pick it up cheap go for it, I'll probably double dip on this when it's released on Blu-Ray in the US.
Romero is offline   Reply With Quote
Old 03-07-2008, 8:34 PM   #4 (permalink)
inzaman's Avatar
Thanks: Gave 91, Got 365
Originally Posted by Romero View Post
, if you can pick it up cheap go for it,.
You can its £3.99 at HMV, i cannot comment on the PQ as i only ordered it the other day but at £3.99 it was too low to resist. I too like Carpenter's early work
Visit my Home Cinema here
inzaman is offline   Reply With Quote
Old 05-07-2008, 1:52 PM   #5 (permalink)
dannydj's Avatar
thanks guys grabbed it from hmv - at that price even a small upgrade it will be worth it .......as i must watch this about three times a year
dvd, fog
