| The Warriors - Comic book transitions problems
Just received my copy of The Warriors on Blu-ray. Had a quick look just to check it out, and noticed some problems with the comic book transitions that have been inserted into the movie as part of the director's cut.
It's as if the new bits have been filmed on interlaced video, and then badly deinterlaced when mastered for HD. As soon as there is motion in the comic book bits there is horrible blurring. When you step pause through these sections, you can see that each frame seems like two separate frames mixed together.
It can be seen right from the start, as soon as the first bit has finished panning down slowly, it does a quick pan up and to the right, and the blurry artifacts are really jarring and out of place.
Has anyone else noticed this? I'm surprised no one seems to have mentioned this issue in any online reviews of the disc, but then I rarely trust online reviews as the review equipment they use always seems to be lacking.
For reference, I'm using a PS3 with forced 1080p 24Hz output switched on, sent to a Pionner LX608D. The PS3 and the TV are not doing any deinterlacing, so it seems this issue is in the source itself.
Thoughts people?
