Go Back   AVForums.com > Movies, TV Programmes and Music > Movies and TV Programmes On Disc and Downloaded
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewNorth By Northwest (50th Anniversary Edition Blu-ray Book) Blu-ray ReviewScrooge (A Christmas Carol) Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray Review
Léon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray Review
Dolby TrueHD vs Dolby Digital - worth the extra? telford_mike AV Amplifiers and Receivers 38 16-08-2007 6:05 PM
is sky audio digital out pure dolby digital? any DTS or EX info? GrahameD Sky and Sky+ 7 07-12-2006 4:08 PM
InterVideo delivers first software HD DVD disc player to feature Dolby TrueHD and Dolby Digital Plus The News Bot Home Cinema and Tech News 0 13-06-2006 11:00 AM
Dolby licenses Dolby Digital multichannel encoding technology for use in new digital video editing software The News Bot Home Cinema and Tech News 0 23-03-2005 2:00 AM
Old 26-03-2008, 7:33 AM   #1 (permalink)
Thanks: Gave 2, Got 5
Blade Runner:Audio, BluRay (dolby digital) VS HD-DVD (dolby digital PLUS)
okay so blurays versions has a bit rate of 640kbps, so what bit rate is the HD-DVD versions, and is it better?
i bought the 5 disc bluray last year but also own a xe1 hd dvd player.
just wanted to know if the sound is better so i can get the 5 disc hd dvd set before it becomes deleated
thanks in advance
RandomHajile is offline   Reply With Quote
Old 26-03-2008, 11:57 AM   #2 (permalink)
cicada78's Avatar
Thanks: Gave 140, Got 36
Re: Blade Runner:Audio, BluRay (dolby digital) VS HD-DVD (dolby digital PLUS)
The US Blu-Ray has True HD.
Visual: Panasonic TH42PZ80, Toshiba HD-EP35, Samsung BDP-1400, Sky HD, Popcorn Hour A-100, XBOX 360, Sony RDR-GX350, Pioneer DV-575A Audio: Pioneer VSX-D2011, Rega Brio, Rega Planet, JM.Lab Chorus 706S, Chorus CC 700, MJ Acoustic Ref200 Sub, Pioneer PDR-W839 CD Recorder, Sony PS-J20 Turntable.
cicada78 is offline   Reply With Quote
Old 26-03-2008, 12:49 PM   #3 (permalink)
richribbon09's Avatar
Thanks: Gave 26, Got 43
I am not sure if the US releases differed from the UK releases, but here are the specs on the both the US Blu-ray and US HD-DVD versions
HD-DVD:
Technical Specs
* HD DVD/DVD
* HD-30 Dual-Layer Discs/DVD-9 Dual-Layer Discs
* Five-Disc Set
Video Resolution/Codec
* 1080p/VC-1
* 480p/i/MPEG-2 (Supplements Only)
Aspect Ratio(s)
* 2.40:1
Audio Formats
* English Dolby TrueHD 5.1 Surround (48kHz/16-bit)
* English Dolby Digital 5.1 Surround (640kbps)
* French Dolby Digital 5.1 Surround (640kbps)
For the Blu-ray version:
Technical Specs
* Blu-ray/DVD
* BD-50 Dual-Layer Discs/DVD-9 Dual-Layer Discs
* Five-Disc Set
* 1080p/VC-1
Aspect Ratio(s)
* 2.40:1
Audio Formats
They look the same to me - both have Dolby TrueHD.
There's no time...
richribbon09 is offline   Reply With Quote
Old 26-03-2008, 12:50 PM   #4 (permalink)
So, to answer your question...No, you wont get any better sound by getting the HD-DVD version.
There's no time...
Old 26-03-2008, 7:10 PM   #5 (permalink)
Indiana Jones's Avatar
Thanks: Gave 18, Got 756
On both HD-DVD and Blu-ray the new cut of Blade Runner has a TrueHD track but the 4 other cuts on HD-DVD have DD+ tracks whereas the same 4 cuts on Blu-ray only have DD.
Sony 40V3000 / Sony STRDG910 / UK XBox 360 Elite / Panasonic BD-35 (Multi-region DVD & BD) / HD-DVD & BD Media Centre
Indiana Jones is offline   Reply With Quote
Old 27-03-2008, 2:28 PM   #6 (permalink)
Thanks: Gave 192, Got 46
Yep...HD-DVD is DD+, Bluray is just DD
Samsung LE40R74BD, Pace Sky+ 80/80GB, Pace Twin 80GB PVR, Samsung DVD-HD950, Yamaha RX-V100D, Jamo A310/A3SUB.1, XBox 360 Premium & HD-DVD, US PS3 60GB, Nintendo Wii, Belkin 'Pure AV' isolator, Logitech Harmony 360.
Xbox 360 gamertag: leamspaceman/Wii console No: 1218 2028 2771 0080 Spaceman69
leamspaceman is offline   Reply With Quote
Old 27-03-2008, 4:32 PM   #7 (permalink)
Geoff_D's Avatar
Thanks: Gave 49, Got 82
Um...they're both at the same bitrate though. I very much doubt that they sound any different.
Geoff_D is offline   Reply With Quote
Old 27-03-2008, 6:15 PM   #8 (permalink)
Thanks: Gave 0, Got 7
Marek
MarekM is offline   Reply With Quote
Old 27-03-2008, 6:43 PM   #9 (permalink)
Probaley true, thought I would just clear up the confusion.
Old 27-03-2008, 11:10 PM   #10 (permalink)
yes i knew the final cut had dolby true hd thanks
i was refering to the other discs
the thing is, does anyone actually know what bit rate is the DD PLUS track
i think its like 1.5mb minimum!!!
the thing that people are confused with is that via digital/optical output it down samples to DD at max bit rate of 640kbps...
same if you chose true HD, you will only "get" 640kbps in to your decoder...
anyways i just thought there was a real way of knowing how to see what bit rate the hd dvd versions is.#
furthermore i would add that if you have a XA1 or A1 hd dvd player it will be 24bit DTS at 1.5mb output from the digital coax!!!
so that converts DD pluss and true HD to 24 bit DTS!!
Old 28-03-2008, 12:00 AM   #11 (permalink)
Geoff_D's Avatar
*Sigh* Universal are known for their 1.5mbps DD+ encodes, but Warners have persisted with low bitrate DD+ encodes and have never (to my knowledge) gone beyond 640kbps. Do a search for a few reviews from American sites (I would link to some but they'd be removed by the mods) and ye shall soon see the light.
Old 28-03-2008, 6:10 AM   #12 (permalink)
Thanks: Gave 277, Got 422
All Warner titles on HD DVD with DD+ are encoded @640 Kbps and NOT 1.5 Mbps.
Blu-ray : 177 + 4* + + (1* + 4* + 8) ; HD DVD : SAYONARA
lgans316 is offline   Reply With Quote
blade, bluray, digital, dolby, hddvd, runneraudio
