| Re: Which Bourne?
Bourne Identity : U.K version because it has 1 extended scene.
Bourne Supremacy : Any version would do.
Bourne Ultimatum : Touch choice. I have the U.S COMBO version that happens to work on my player properly. YMMV with COMBO. The U.S version has Dolby True HD track which is slightly better than the DD+ track.
Note:
Also keep in mind that the non U.S versions displays language selection menu and then the annoying copyright message than runs for a minimum of 30 seconds. If you can put up with this irritating stuff then you can very well buy the U.K version.
__________________ Blu-ray : 177 + 4* + + (1* + 4* + 8) ; HD DVD : SAYONARA |
