Go Back   AVForums.com > Movies, TV Programmes and Music > Movies and TV Programmes On Disc and Downloaded
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Record Sky and create DVD's query Phineus PVRs and VCRs 1 02-12-2007 1:10 PM
Flipper ! Garf Past Entries 5 19-06-2006 1:34 PM
HD Query - Does XBOX 360 play DVD's in HD jf935298 Xbox 360 HD DVD drive 5 18-05-2006 1:37 PM
Flipper or non-flipper?! PoochJD Movies and The Cinema 1 06-02-2001 9:22 AM
Old 06-01-2008, 1:21 PM   #1 (permalink)
Thanks: Gave 2,445, Got 927
Question HD-DVD Query - Flipper HD-DVD's
Just a quick question, as it was something I'd not noticed before on a Hi-Def DVD.
I note on the back of "Flag Of Our Fathers", that the film is on Side A, and the extras on Side B - hence, it's essentially a "flipper" disc.
Is this a simple mistake on the packaging, or do HD-DVD's and/or Blu-Ray discs sometimes need to be flipped over?! If so, what on earth are companies doing, when the space on an HD format DVD should be enough to get everything on one side of the disc, in a dual-layer format, without the need to flip the disc over? Failing that, are companies just being stupid, and not using the new HD format to its proper specs, like in the early days of regular DVD discs? Or am I simply being really stupid here?
If I had to flip the disc over, then that just seems mad, as no one likes "flipper" discs, irrespective of the format the film/show is on!
Pooch
PoochJD is offline   Reply With Quote
Old 06-01-2008, 5:01 PM   #2 (permalink)
Thanks: Gave 124, Got 983
Re: HD-DVD Query - Flipper HD-DVD's
I never thought of them as flippers. Flippers to me are the old versions of Starship troppers, Armageddon etc which are split in the middle during the film. Even those didn't bother me. I have laserdiscs that have to be flipped/changed discs three or four times.
nwgarratt is offline   Reply With Quote
Old 07-01-2008, 4:19 AM   #3 (permalink)
Sonic67's Avatar
Thanks: Gave 616, Got 899
Maybe it's a version of a combo disk. HD film on one side. SD extras on the other.
Lots of stuff. Some silver, some black.
Sonic67 is offline   Reply With Quote
Old 07-01-2008, 10:18 PM   #4 (permalink)
Greg's Avatar
Thanks: Gave 99, Got 752
Moved to HD Movies forum.
My opinions expressed here are not necessarily those of the AV Forums or the associated websites.
Science created him. Now Chuck Norris must destroy him!
Greg is offline   Reply With Quote
Old 07-01-2008, 10:29 PM   #5 (permalink)
Adam_uk's Avatar
Thanks: Gave 45, Got 85
i think you must mean a combo disc. It's a normal SD DVD one side and the HD DVD on the other side
Current kit- Sony 40" V3000, Onkyo 875, Kef 3005SE speaker package, Toshiba HD DVD XE1, Playstation 3, X-box 360, Nintendo Wii, Sky HD
Adam_uk is offline   Reply With Quote
Old 07-01-2008, 11:12 PM   #6 (permalink)
Spidey987's Avatar
Thanks: Gave 168, Got 174
Because Flags was published by Paramount in the US, who use 2 discs on their special editions and Warner UK normally try to stick with a single disc, they put the HD movie on one side and the HD extras on the other.
So essentially it is a flipper and to my knowledge the only one.
Spidey987 is offline   Reply With Quote
flipper, hddvd, query
