Go Back   AVForums.com > Movies, TV Programmes and Music > Movies and TV Programmes On Disc and Downloaded
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
will the a1 upscale backed up dvd's in region 0 (originally region 2)? jamiev HD DVD Players 1 02-01-2007 12:13 AM
Region 3 dvd's dts197 Movies and The Cinema 5 07-09-2006 12:27 PM
Region 3's? / Region 3 DVD's - as good as R2 or what? Drew C Movies and The Cinema 18 15-04-2004 3:35 PM
Region 3 dvd's red2003devil Movies and The Cinema 12 04-02-2004 9:47 AM
Old 18-11-2007, 6:50 PM   #1 (permalink)
Thanks: Gave 58, Got 77
HD DVD's - which region?
I keep noticing that people refer to certain countries versions of HD DVDs when expressing a preferance when buying. Having only just taken the plunge I am puzzled as to where to get my discs from. I have bought a few from the US and a few from here and apart from the Federal warning, what's the difference? Seeing as Unforgiven bought from Tesco had the same Federal warning as other US discs, are they not just the same films, albiet with different warnings?
Thanks for your time in reading this.
Bill
Gingerbillc is offline   Reply With Quote
Old 18-11-2007, 7:03 PM   #2 (permalink)
signs's Avatar
Thanks: Gave 807, Got 996
Re: HD DVD's - which region?
there is no difference ,although some maybee "combo" disc's (plays both SD/HD)
XBOX 360 paramount signs PSN Paramountsigns
Lines .. i must not be confrontational, i must not be confrontational,i must not be confrontational i must not be confrontational,i must not be confrontational,
signs is offline   Reply With Quote
Old 18-11-2007, 7:07 PM   #3 (permalink)
Thanks: Gave 37, Got 86
Originally Posted by Gingerbillc View Post
Bill
With some releases, the transfer will be the same, from the same master etc.
With other releases, the source material will be a different master, the transfer will be a different encode. A good example of this is Serenity, the US and UK versions of which are different transfers with the UK encode being done some six months later and benefiting from Microsoft's, by that time, improved VC-1 codec. The results, according to some reviewers are noticeable in that the PQ of the UK release is ever so slightly better than the US release.
Aside from the main movie, differences between releases will be found in the packaging, different subtitles, different audio tracks, different extras etc. Another difference is that some US combo releases may be non-combo elsewhere.
AES256 is offline   Reply With Quote
dvd, region
