Go Back   AVForums.com > Movies, TV Programmes and Music > Movies and TV Programmes On Disc and Downloaded
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 03-10-2007, 10:54 AM   #1 (permalink)
evolved77's Avatar
Thanks: Gave 8, Got 6
StarWars HD
Came across a post yesterday, with some chap claiming to have uploaded all six Starwars movies in HD.
Im a bit confused, I know they have not yet been released on Blu-ray or HD-DVD, so can this be true?
I suspect theyre just SD and he's confused or showing off!
...Also, for any SW fans - Family Guy, Season 6, episode 1... Its basically Family Guy version of Episode IV... hilarious.
evolved77 is offline   Reply With Quote
Old 03-10-2007, 11:10 AM   #2 (permalink)
Keith Hurst's Avatar
Thanks: Gave 126, Got 248
Re: StarWars HD
I think that these are an amalgam of HD sources as broadcast on Sky+ and other similar HD channels throughout Europe.
One of the guys at the work says he has them all also.
KH
Blu-ray and DVD Reviewer
The Best DVD & HD Resource AVForums Movie Reviews. Bookmark It Now!
My opinions expressed here are not necessarily those of the AV Forums or the associated websites.
Keith Hurst is offline   Reply With Quote
Old 03-10-2007, 11:38 AM   #3 (permalink)
evolved77's Avatar
Re: StarWars HD
Ok, I've checked what the guy has said in the post...
"I have uploaded all 6 Star Wars movies in High Definition !
These are HDTV rips, because star wars is not available in HDDVD or BluRay Disc"
I still dont quite understand this though. If the films aren't available in HD, even showing them on a HD channel, SkyHD Movies, surely they won't be the same quality as the eventual official HD releases?
Old 03-10-2007, 11:58 AM   #4 (permalink)
PAH
Thanks: Gave 3, Got 35
Re: StarWars HD
Seeing as many movies aren't officially available in HD yet, I've often thought Sky and other HD channel providers are simply upscaling SD material to HD resolutions, so it's not true HD.
Maybe I'm wrong but I could be right. Hard to prove unless someone works at Sky or is in the business and can explain how they get hold of this material in true HD. If the studios are supplying broadcasters with HD material it's only a small step to provide it to consumers too, so why delay taking that step?
PAH is offline   Reply With Quote
Old 03-10-2007, 12:36 PM   #5 (permalink)
Conspicuous Member
Singh400's Avatar
Thanks: Gave 507, Got 1,150
Re: StarWars HD
What they do is use a uncompressed source (.ts files) for the HD releases usually from HDTV streams. Then re-encode them using vc1/x264/wmvhd.
I don't think that SkyHD upscales movies. Or any other HD movies channel.
[CPU: Q9450 @ 3.6Ghz|RAM: Corsair PC2-8500 (2x2GB)]
[MOBO: Asus P5Q Deluxe (1406)|HDD#1: Samsung F1 750GB]
[HDD#2: OCZ SSD V1 32GB|GFX: BFG 9800GTX+ OC|PSU: Corsair HX 620W]
Singh400 is offline   Reply With Quote
Old 03-10-2007, 5:55 PM   #6 (permalink)
Thanks: Gave 31, Got 223
Re: StarWars HD
Sorry but if you can't actually tell the difference between an HD master and an SD one I'd stear clear of high definition in general.
Mr.D is offline   Reply With Quote
Old 03-10-2007, 8:37 PM   #7 (permalink)
Thanks: Gave 52, Got 70
Re: StarWars HD
should have gone to specsavers.
zz101 is offline   Reply With Quote
Old 05-10-2007, 4:05 PM   #8 (permalink)
Thanks: Gave 8, Got 11
Re: StarWars HD
All 6 Star Wars movies have been broadcast in HD 1080i at regular intervals. Sky has purchased the rights. They are all sitting in my HD box, and are stunning HD quality, esp the last 3. Not bothered about when released on disk, cos no need (would need a bigger TV/projector to benefit from 1080p).
They are also available in compressed and uncompressed versions of the HD broadcasts in torrents from the usual dodgy places.
Fujitsu 50" 58 series PDP | Toshiba E35 HD-DVD | Onkyo 674 amp | Marantz 7600 dvd player | Jamo 5.1 a10 speakers | xbox 360 | Sky HD
TranceFan is offline   Reply With Quote
starwars
