Go Back   AVForums.com > Movies, TV Programmes and Music > Movies and TV Programmes On Disc and Downloaded
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 26-09-2007, 5:25 PM   #1 (permalink)
Thanks: Gave 21, Got 39
Planet Earth Error Code 408bc504
Am trying to play disc 4 epp 2 and receiving the above code any ideas
Please
mikehb is offline   Reply With Quote
Old 26-09-2007, 5:50 PM   #2 (permalink)
Re: Planet Earth Error Code 408bc504
bump
Old 26-09-2007, 5:58 PM   #3 (permalink)
Azzin's Avatar
Thanks: Gave 1,995, Got 446
What are you trying to watch it on?
Google is your friend though:
http://www.avforums.com/forums/showt...32#post5319932
http://www.google.co.uk/search?sourc...Code+408bc504+
Optoma HD70 with 95" Screen|Sky HD|Onkyo TX-SR606|Jamo A102s|120 gig XBOX 360|USA 500 gig PS3|Wii|Harmony One
Azzin is offline   Reply With Quote
Old 26-09-2007, 6:23 PM   #4 (permalink)
Many thanks for quick reply.
Got this disc set in July from Axelmusic. Been playing ok since July,
just updated to v2.2 last Friday then this error comes up.
Only on this disc sofar with any problems. Think its a call to Tosh to sort
Many thanks
Old 27-09-2007, 6:01 PM   #5 (permalink)
UPDATE.
Spoke to Tosh this morning explained problem re (error code) he asked what ver software am using, v2.2 as their disc arrived last Fri, prior to that Planet Earth worked perfectly. After a long wait he came back and said they had several machines running in the workshop using v2.2 with no errors.
They want the player returned complete with any/all affected discs for tests. I said will give it a further weeks use with a selection of discs and see if any more errors happen.
Also noticed that all discs in the set had scratches on them as if lazer in the player catching them some how.
Let you know the outcome as it unfolds.
Old 07-11-2007, 7:15 PM   #6 (permalink)
Update:
Having contacted Tosh re error code seems that as it was a U.S. release, here in the U.K. they are unable to fix the problem. So as i am unable to return this set to Axelmusic as it was bought back in July as a birthday present from my son. I contacted 2 Entertain (distributor) at the weekend and this morning i received an email saying due to inventory issues it was not possible for me to buy a disc from the set to replace the damaged 1, they would replace the entire set with a U.K. edition free of charge.
Many thanks to 2 Entertain excelent company
Old 07-11-2007, 8:31 PM   #7 (permalink)
Jim Morrison's Avatar
Thanks: Gave 183, Got 190
Originally Posted by mikehb View Post
Update:
That's jolly good of them - the UK edition comes with a 5th disc aswell. Result!
Jim Morrison is offline   Reply With Quote
408bc504, code, earth, error, planet
