Go Back   AVForums.com > Movies, TV Programmes and Music > Movies and TV Programmes On Disc and Downloaded
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 24-09-2007, 9:30 PM   #1 (permalink)
Thanks: Gave 52, Got 70
Sticky boxes!!
Anyone got any (serious) suggestions for removing all the stickers and security devices that seem to come with MT's Blu-ray's? It literally took several minutes to get into my copy of HoaTC and now the box looks crap and is unpleasantly sticky.
zz101 is offline   Reply With Quote
Old 24-09-2007, 9:31 PM   #2 (permalink)
Dave's Avatar
Thanks: Gave 973, Got 896
Re: Sticky boxes!!
Stanley knife and patience.
My opinions expressed here are my own and do not represent those of AV Forums.
My Flickr
Dave is offline   Reply With Quote
Old 24-09-2007, 9:46 PM   #3 (permalink)
Location: Deep inside Devon (the county, not the porn star)
Thanks: Gave 15, Got 59
Re: Sticky boxes!!
A little bit of rubbing alcohol (isopropyl alcohol) on some kitchen roll will
remove the sticky bits that are left.
cobbler is offline   Reply With Quote
Old 24-09-2007, 9:47 PM   #4 (permalink)
Thanks: Gave 292, Got 207
Re: Sticky boxes!!
I am dying to know the answer aswell.......
dbs2 is offline   Reply With Quote
Old 24-09-2007, 10:06 PM   #5 (permalink)
dts197's Avatar
Thanks: Gave 422, Got 208
Re: Sticky boxes!!
I'd imagine something like nail varnish remover would do a good job. I use plenty of furniture polish on a duster.
It's not just MT, it's Region 1 dvd's and Region B blu-ray & hd-dvd's that have annoying security devices.
SET UP PICS
FILM COLLECTION
dts197 is offline   Reply With Quote
Old 24-09-2007, 11:04 PM   #6 (permalink)
Thanks: Gave 6, Got 3
Re: Sticky boxes!!
I've also noticed that if you take discs you've bought online into other stores, they will often set off the security sensors at the entrance.
I think the tags that are in the cases are activated by default!
jtotheb is offline   Reply With Quote
Old 24-09-2007, 11:32 PM   #7 (permalink)
Conspicuous Member
Pincho Paxton's Avatar
Thanks: Gave 60, Got 307
Re: Sticky boxes!!
I just use washing up liquid, and it works fine.
The seating distance thing is quite annoying. Yeah it looks great from 20ft away.. so does my ex!!!. Snowflakes come from another dimension!
Pincho Paxton is offline   Reply With Quote
Old 25-09-2007, 8:46 AM   #8 (permalink)
BadAss's Avatar
Thanks: Gave 138, Got 196
Re: Sticky boxes!!
I think this complaint as been reported to the studio's and then new stickers are now far less sticky.
BadAss is offline   Reply With Quote
Old 25-09-2007, 8:54 AM   #9 (permalink)
Spidey987's Avatar
Thanks: Gave 168, Got 174
Re: Sticky boxes!!
Are the stickers on Blu-ray different to those on HD DVD? Because I haven't had any problems yet and was wondering if I've just been lucky.
Spidey987 is offline   Reply With Quote
Old 25-09-2007, 9:12 AM   #10 (permalink)
Sonic67's Avatar
Thanks: Gave 616, Got 899
Re: Sticky boxes!!
Use zippo lighter fluid and cotton wool.
Sonic67 is offline   Reply With Quote
Old 25-09-2007, 5:46 PM   #11 (permalink)
Thanks: Gave 10, Got 28
Re: Sticky boxes!!
Serious overkill in some places (on every side of the "open" box and under a wrapper) just completely pointless imo
I have damamged a couple of boxes by trying to get the silly things off
HugoFJH is offline   Reply With Quote
Old 25-09-2007, 6:55 PM   #12 (permalink)
Racquel Darrian's Avatar
Thanks: Gave 42, Got 62
Re: Sticky boxes!!
Originally Posted by dts.1978 View Post
I'd imagine something like nail varnish remover would do a good job......
That's usually acetone based and it will melt plastic.
Sony KDF-E50A12U, Toshiba HD-EP35 HD DVD player, 7.1 Onkyo TX-SR705E Amp, Mission 773 front main speakers, Mordaunt Short Speakers everywhere else, Audiosource 10001 Sub, Xbox 360, Wii, PS3 60GB (320GB HD installed), VirginMedia V+ Box
Racquel Darrian is offline   Reply With Quote
Old 25-09-2007, 7:43 PM   #13 (permalink)
Re: Sticky boxes!!
If you want to recreate the alien blood melting through a metal hull (as seen in alien) then get some toluene and a large block of polystyrene. It really is rather impressive. Sorry that that was off topic but it is worth it.
boxes, sticky
