24-09-2007, 1:11 PM
#1 (permalink)
| | Member
Thanks: Gave 69, Got 127 | Underworld - US/UK Differences?
Does anyone know what differences there are between "Underworld: Special Extended Edition" (UK version) and "Underworld (Unrated)" (US version)?
Looking at the box in HMV, the UK one doesn't list a PCM track (which is something I had read previously), but I believe the US version does have one (MT list it as having one)
Anyone know if there are any differences with US/UK versions of Underworld: Evolution as well? e.g. no PCM track on the UK one?
__________________ Samsung LE40M87BD | Onkyo TX-SR875 | SVS SBS-01 | SVS PB13U | Virgin V+ | Panasonic DMR-EX75EB | Xbox 360 | PS3 | Toshiba HD-EP35 | Behringer DSP1124P | Marantz CD63SE |
24-09-2007, 1:18 PM
#2 (permalink)
| | Ex Member
Thanks: Gave 138, Got 196 | Re: Underworld - US/UK Differences?
The UK uses MPEG2 and the US uses AVC.
24-09-2007, 1:19 PM
#3 (permalink)
| | Illustrious Member
Thanks: Gave 885, Got 1,686 | Re: Underworld - US/UK Differences? Quote:
Originally Posted by Andori Does anyone know what differences there are between "Underworld: Special Extended Edition" (UK version) and "Underworld (Unrated)" (US version)?
Anyone know if there are any differences with US/UK versions of Underworld: Evolution as well? e.g. no PCM track on the UK one? | Use dvd compare for comparisons.
Here is the search for Underworld. http://www.dvdcompare.net/comparisons/film.php?fid=4583
__________________ Click 4 Pics 70" 1080p SXRD Pio AX4ASi-S, SkyHD, 360Elite, 360, PS3, Wii, Bose AM15, NevoSL Watercooled Games HTPC LC17, P6T Deluxe, i7 920@4.0Ghz, DTek FuzionV2, 4870X2+EK waterblock, 64Gb SSD, 6Gb, Forte, Enermax 1250W Rev+, Zalman Reserator XT, PA120.3 - 2nd Gaming PC, 2nd HTPC, Pronto, 50PZ80 |
24-09-2007, 1:26 PM
#4 (permalink)
| | Member
Thanks: Gave 0, Got 2 | Re: Underworld - US/UK Differences?
The UK version's soundtrack is listed English: 5.1 Surround Sound, no mention of a HD audio track anywhere. The case also has Dolby Digital on the back, but when playing back my amp recieved a DTS signal. From a UK PS3 connected via optical.
Haven't watched the whole of the second film but the quick go I had with the disc showed it was set up the same.
24-09-2007, 1:56 PM
#5 (permalink)
| | Member
Thanks: Gave 0, Got 6 | Re: Underworld - US/UK Differences?
How about the other EIV releases like Next, Hostage and U-571 ???
Any specs available or did someone got a look at the covers for these ??
Thanx
__________________ "What If Tomorrow The War Could Be Over.......Isn't That Worth Fighting For........Isn't That Worth Dying For ?!! " |
25-09-2007, 11:27 AM
#6 (permalink)
| | Member
Thanks: Gave 69, Got 127 | Re: Underworld - US/UK Differences? Quote:
Originally Posted by Razor | That only refers to the DVD versions and not the Blu-Ray ones, which is what I was mainly interested in. Saying that, Assuming that the BD version uses the same cut as the DVD version, then the US and UK versions will be the same. Quote:
Originally Posted by BadAss The UK uses MPEG2 and the US uses AVC. | Seems strange that they would use different encoding
As they seem to have left the PCM tracks off the UK versions, guess I'll be ordering the US versions as they are supposed to work on a UK PS3
25-09-2007, 11:38 AM
#7 (permalink)
| | Illustrious Member
Originally Posted by Andori That only refers to the DVD versions and not the Blu-Ray ones, which is what I was mainly interested in. Saying that, Assuming that the BD version uses the same cut as the DVD version, then the US and UK versions will be the same.
No worries mate. They have the listings for the HD DVD and BD for Underworld Evolution but not the first underworld. Strange that.
Anyway good luck and I hope you find what your looking for.
