21-09-2007, 3:44 AM
#1 (permalink)
| | Member
Thanks: Gave 9, Got 86 | Alexander Revisited The Final Cut HD DVD, got me an system error
Well got my imported alexander yesterday and it was almost good.
Except the second part (disc 2) of the movie which didn't play at all.
Have the Toshiba HD-E1 player with firmware 2.0
21-09-2007, 9:29 AM
#2 (permalink)
| | Senior Member
Thanks: Gave 59, Got 70 | Re: Alexander Revisited The Final Cut HD DVD
I think there is a new firmware update out version 2.2 ?
I keep meaning to shove a lead into my HD-E1 and get it but life keeps taking over.
don't know if it will help with your second disc problem though.
__________________ too much equipment to list... with a setup in every room... and I never seem to get rid of anything ! |
21-09-2007, 9:49 AM
#3 (permalink)
| | Prominent Member
Thanks: Gave 517, Got 372 | Re: Alexander Revisited The Final Cut HD DVD
I saw someone on avsforum say they had this issue and went into the setup menu and changed the twin format from HD-DVD to DVD and it played. Seems a strange solution, but hey it will only take a couple of seconds to try so worth doing before you send it back.
21-09-2007, 3:00 PM
#4 (permalink)
| | Member
Thanks: Gave 9, Got 86 | Re: Alexander Revisited The Final Cut HD DVD
Ok thanks both of you, will try the set up thing and then the firmware via helpdesk .
21-09-2007, 5:06 PM
#5 (permalink)
| | Member
Firmware 2.2 did it
This has been the longest Intermission i ever experienced.
By the way, the movie looks really good and ok sound.
Have a nice weekend, thanks again.
21-09-2007, 8:53 PM
#6 (permalink)
| | Senior Member
Thanks: Gave 59, Got 70 | Re: Alexander Revisited The Final Cut HD DVD Quote:
Have a nice weekend, thanks again. | glad you got it sorted.
22-09-2007, 1:32 PM
#7 (permalink)
| | Member
Thanks: Gave 242, Got 35 | Re: Alexander Revisited The Final Cut HD DVD
So, how is the image quality of this movie, compared to the best of other HD discs pls?
22-09-2007, 4:59 PM
#8 (permalink)
| | Member
Image is really good. Sound is DD+ at 640kbps, sounds better than might believe.
22-09-2007, 7:16 PM
#9 (permalink)
| | Senior Member
Thanks: Gave 254, Got 167 | Re: Alexander Revisited The Final Cut HD DVD
Thanks High Def DVD, that looks incredibly good, glad I ordered a copy now. The SD disc of the shorter (168 min) cut was good enough for SD but this looks much better.
25-09-2007, 6:14 AM
#10 (permalink)
| | Eminent Member
Thanks: Gave 1,138, Got 7,577 | Re: Alexander Revisited The Final Cut HD DVD
Pioneer KRP-600M, Onkyo 876, M&K LCR 750, M&K M4T, SVS PC13 Ultra  PS3 Slim, Oppo BDP-83, XE1, Logitech 1000 remote, wildlife pond in back garden and six fish tanks in the house.
Show me Potato Salad! |
01-10-2007, 5:46 PM
#11 (permalink)
| | Member
Thanks: Gave 106, Got 15 | Re: Alexander Revisited The Final Cut HD DVD
can anyone explain please in simple terms why the second disc will not play on my xe1 with the new updated software.disc 1 is great disc 2 plays the dreamworks bit and thats as far as it gets.is this not a fault with the disc.thanks for any info.
01-10-2007, 6:30 PM
#12 (permalink)
| | Member
Thanks: Gave 9, Got 86 | Re: Alexander Revisited The Final Cut HD DVD Quote:
Originally Posted by harry m can anyone explain please in simple terms why the second disc will not play on my xe1 with the new updated software.disc 1 is great disc 2 plays the dreamworks bit and thats as far as it gets.is this not a fault with the disc.thanks for any info. | Sorry to hear, same thing as for me earlier?
Well, firmware 2.2 did it for me, are u sure you do have the 2.2 in the player and not the 2.0 in the maintenance?
I haven't any answers, was in contact with toshiba 2 weeks ago and they said there wasn't any issues with this movie at all and as noted 2.2 did help me with my E1.
What if a restart helps, you unplug the power cord and reconnect the player from there?
02-10-2007, 5:10 PM
#13 (permalink)
| | Member
thanks for the reply,i have the 2.2 installed and this is the only disc i have ever had a problem with so i guess i will have to live with it.
02-10-2007, 6:54 PM
#14 (permalink)
| | Senior Member
Thanks: Gave 254, Got 167 | Re: Alexander Revisited The Final Cut HD DVD Quote:
Originally Posted by harry m thanks for the reply,i have the 2.2 installed and this is the only disc i have ever had a problem with so i guess i will have to live with it. | I also had a problem with the second disc. Try initialising the disc under the general maintenance on set-up - failing that try changing the disc on the picture set-up to PAL rather than AUTO.
04-10-2007, 2:46 AM
#15 (permalink)
| | Member
From other users:
"I had the same problem on my HD-E1 (European A20(?)) The display on the player said "NONPLAY" and i got the message 'System Error Accured'
I solved it by clearing all the entries in the persisten storage of my drive and then insert the disc again."
"The first time I tried the second disc, it gave me "System Error" after the Warner logo. I ejected and reloaded, and it played fine after that."
"Deleting all entries for Warner Bros. in the persistent storage of my HD E1 worked for me."
