Go Back   AVForums.com > Movies, TV Programmes and Music > Movies and TV Programmes On Disc and Downloaded
Latest AVForums Movie Reviews
Gray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray Review
Taking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray Review
Old 04-08-2007, 1:21 PM   #1 (permalink)
Thanks: Gave 853, Got 599
US Blu-Ray cases - very poor quality - 3 all broken
Afternoon all,
Has anyone else had a problem with the inferior quality of US Blu-Ray cases?
I now have 3, Letters from Iwo Jima, Flags of our Fathers and most recently 300.
The first two were bought advertised as "new" from a private Ebay seller and the copy of 300 was from MovieTyme.
All three of them arrived with the centre pins broken that are supposed to hold the disc in place.
They are all manufactured by "Elite" whom I assume are the US standard.
With two of them two of the four pins are broken so they fail to secure the disc, with 300 the leftmost one is broken so it just about holds it in place.
I find it very poor that the cases for all 3 new discs I have purchased so far have had the same fault.
They even look inferior to the standard "Amaray" European cases with no embossed logo, much thinner, and a much lighter shade of blue.
They are basically a far cheaper product.
Anyone else have the same issues?
Example pic:
http://img172.imageshack.us/img172/5...1080709yh5.jpg
KeanosMagicHat is offline   Reply With Quote
Old 04-08-2007, 1:29 PM   #2 (permalink)
Thanks: Gave 31, Got 22
Re: US Blu-Ray cases - very poor quality - 3 all broken
Ive got both Blu-ray and HD DVD and not had any issues. What annoys me is the difference in width of HD DVD, some are thin like Blu-ray cases, but others are the same as standard DVD cases.
ISEEDUMBPEOPLE is offline   Reply With Quote
Old 04-08-2007, 1:37 PM   #3 (permalink)
Thanks for the reply.
Do you definitely have US cases, yeah?
How can I be so unlucky as to have 3 of 3 all broken thus far if there is not an inherent quality problem?
Old 04-08-2007, 1:47 PM   #4 (permalink)
Rasczak's Avatar
Thanks: Gave 489, Got 631
Interesting - which titles have you had in thick cases? Or are you mixing which regions you buy from? All US purchases (HD DVD and BluRay) come in 'thin' cases. Most, but not all, of UK purchases come in 'DVD thickness' cases (whether HD DVD or BluRay).
Have to admit I haven't had any issues which any of my cases broken either (almost all are US). I tend to order from Amazon.com who seem to package things quite well.
PC and Console Gamer: Steam (Rasczak) - Live! (Rasczak UK) - PSN (Rasczak) - When will 'Games For Windows - LIVE' be Steamed?
Rasczak is offline   Reply With Quote
Old 04-08-2007, 2:00 PM   #5 (permalink)
Ive only just recently purchased the US one and ive removed it once from the case. Maybe theyre just fragile.
The HD DVD titles that came in thin cases are V for Vendetta and Troy, purchased from HMV. The free titles i received from Toshiba (King Kong and Constantine) came in thick cases, as did Batman and Hulk purchased from Play. Still waiting delivery of Matrix Trilogy. I prefer the thin cases and even looked at buying spare cases, but the printed sleeve/inserts arent the same size and id have to trim them .
Old 04-08-2007, 2:10 PM   #6 (permalink)
Just to clarify these cases all arrived in this condition.
When I first opened them there were little bits of blue plastic rattling around inside that used to be the centre pins.
Old 04-08-2007, 2:20 PM   #7 (permalink)
Thanks: Gave 2, Got 5
i prefer the thin cases myself, much better than the thick ones, take up less space too.
I received one like that this week, bluray but a thick case with the centre broken.
davidkn is offline   Reply With Quote
Old 06-08-2007, 6:54 PM   #8 (permalink)
Thanks: Gave 131, Got 17
My blu-ray cases have never been delivered to me broken, but I hate the stickers on the edges of the case. When I have taken them off, they leave an annoying residue on them. Anyone else?
sukhy5 is offline   Reply With Quote
Old 07-08-2007, 12:14 PM   #9 (permalink)
Urien Rheged's Avatar
Thanks: Gave 337, Got 353
I got my copy of 300 today (took 14 days from dispatch) and the plastic clips holding the disc in place were also broken. It was the Blu-Ray version and the case was made by 'ELITE'. I've sent an e-mail to Movietyme
XBOX 360 Elite. 60GB PS3. Sky HD. Sony DAVDZ810 Home Cinema system. Samsung LE46M86BD 46" 1080p HD LCD TV. Sony HDR-CX6EK Full HD Handycam...plus some other stuff..
R.I.P KinkyAffro
Urien Rheged is offline   Reply With Quote
KeanosMagicHat (07-08-2007)
Old 10-08-2007, 2:26 AM   #10 (permalink)
Matrix Trilogy arrived yesterday, and guess what? All three cases had at least one damaged pin. They were the thin and cheap looking 'ELITE' branded ones.
Old 10-08-2007, 4:33 AM   #11 (permalink)
Synchro's Avatar
Thanks: Gave 126, Got 153
I see a trend
Synchro is offline   Reply With Quote
Old 10-08-2007, 7:45 AM   #12 (permalink)
Thanks: Gave 48, Got 41
Yep, my knigdom of heaven blu-ray case was broken as well.
Anyone know where to get replacement cases?
bcopping is offline   Reply With Quote
Old 10-08-2007, 9:36 AM   #13 (permalink)
Update: Got a replacement case in the post yesterday from Movietyme. Thanks Movietyme.
R.I.P KinkyAffro
Old 12-08-2007, 9:29 AM   #14 (permalink)
Conspicuous Member
brian s's Avatar
Thanks: Gave 294, Got 419
Yesterday I attempted to but the Starship Troopers BD from HMV. After I left the shop I had a look at it and found the centre was broken with the disc loose. This was very unusual because I always shake the case to make sure the disc is in place before I buy. Went back for a replacement. Shook the cover, no problem. Got out of the shop and checked again, The disc was loose with the centre broken. The centre had been broken when they used the machine to remove the security tag. The act was violent enough to cause the damage. Tried again with their third and last copy, same result.
Went to Vigin and asked them to remove the tag and open it before I paid for it. This one was ok.
It's an Amaray case. Not very impressive.
All the best
Bri
brian s is offline   Reply With Quote
Old 16-08-2007, 3:46 PM   #15 (permalink)
Thumbs up Re: US Blu-Ray cases - very poor quality - 3 all broken
My replacement came today from MovieTyme too.
Much better quality than the original US "Ellite" branded case.
bluray, broken, cases, poor, quality
