Go Back   AVForums.com > Movies, TV Programmes and Music > Movies and TV Programmes On Disc and Downloaded
Latest AVForums Movie Reviews
Up Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray ReviewLogan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray Review
Star Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray ReviewHeat Blu-ray ReviewMoon Blu-ray Review
Old 03-08-2007, 7:23 AM   #1 (permalink)
featherhall's Avatar
Thanks: Gave 443, Got 86
La Haine ' HDDVD any better than the sd ?
I absolutely love this film, and recently got the steel sd set at a bargain £8. However I noticed that this is available on HDDVD and was wondering if anybody has it, and if so is there any marked improvement over the sd ? cant seem to find any reviews of the HD. Given that it is in Black and White, I am not sure if its worth double dipping, but may do if someone can confirm the quality is better
many thanks
Pioneer Kuro pdp508xd - UK PS3 - Xbox360 Elite - HDDVD - Pioneer DVR-LX60D Recorder - Pioneer VSX-LX60D Amp
featherhall is offline   Reply With Quote
Old 03-08-2007, 7:43 AM   #2 (permalink)
Conspicuous Member
brian s's Avatar
Thanks: Gave 294, Got 419
Re: La Haine ' HDDVD any better than the sd ?
Originally Posted by featherhall View Post
many thanks
I 've ony watched part of it as it has bad 3/2 pulldown problems early on. I have the XE1.
Bri
brian s is offline   Reply With Quote
featherhall (03-08-2007)
Old 03-08-2007, 2:34 PM   #3 (permalink)
Thanks: Gave 1, Got 2
I love the film as well, but can't say the HD version is miles better, but I haven't done a side by side comparison so it probably is better.
At AVSFORUM it got 4-4.5 in the picture quality thread, which is pretty good.
El_Watcher is offline   Reply With Quote
Old 03-08-2007, 5:51 PM   #4 (permalink)
pRot3us's Avatar
Thanks: Gave 324, Got 201
The only review I can find is from a french site here (google translated)
I'll certainly be getting this at some point.
featherhall, have you not seen a well mastered black and white movie in HD? It really is glorious.The only disc I own so far is Good Night and Good Luck and it looks fantastic, if La Haine looks anywhere near as good I'll be well happy
HTPC - Optoma HD20 @ 100" |NEC MultiSync 24WMGX3|Q9550|XFX GTX260 Black Edition|4Gb OCZ Reaper|Asus P5Q|X-Fi fatal1ty FPS|LG Blu Ray writer/HD DVD combo drive|Logitech Z-5500 5.1|VideoMate T750F DUAL DVB-T|74Gb Raptor(16mb)+1.7Tb storage|Antec P180B|dual PS2 gamepads dvds
pRot3us is offline   Reply With Quote
Old 03-08-2007, 7:09 PM   #5 (permalink)
I got Casablanca on HDDVD and it is awesome. I'd seriously recommend it if you like the film - a stunning transfer if ever there was one. I think I will order La Haine, so thanks everyone for the info.
Old 04-08-2007, 9:58 AM   #6 (permalink)
Conspicuous Member
brian s's Avatar
Sorry I didn't give a fuller reply yesreday but I was in a dash to go work. On the XE1 there's bad video judder during the scene early on where the guy walks past the Police and their vans. I checked it on the X Box and another XE1. The fault played the same on both of these. The problem was far worse on the E1. Optimum say it's not a disc fault but it's down to 3/2 pulldown. so be warned.
All the best
Bri
featherhall (04-08-2007)
haine, hddvd
