Go Back   AVForums.com > Movies, TV Programmes and Music > Movies and TV Programmes On Disc and Downloaded
Latest AVForums Movie Reviews
Terminator Salvation Blu-ray ReviewGray Lady Down - Original Motion Picture Soundtrack CD ReviewUp Blu-ray ReviewLéon Blu-ray ReviewNear Dark Blu-ray Review
Logan's Run Blu-ray ReviewTaking of Pelham 1 2 3, The Blu-ray ReviewStar Trek Blu-ray ReviewUFC 100: Lesnar vs. Mir (2009) Blu-ray ReviewThe New York Ripper Blu-ray Review
Old 22-05-2007, 8:50 PM   #1 (permalink)
Thanks: Gave 0, Got 22
Apocalypto Blu-ray
can anyone tell me if this movie will on a uk ps3 thanks.
PSN ID = BigKahunar
rickmoz is offline   Reply With Quote
Old 22-05-2007, 8:53 PM   #2 (permalink)
SeedyR's Avatar
Thanks: Gave 253, Got 330
Re: Apocalypto Blu-ray
Yes it will.
I came to the AV Forums for helpful advice & to hopefully save some money. Now I have a lousy bank balance & the constant urge to upgrade
My Stuff:Panny TH50PZ80B, Onkyo 805, V+, Topfield 5800, Harmony 885, MacBook Pro. 16gb iPhone 3G Consoles: 360 Elite, Wii, PS3 Slim, PSP & DS Lite
SeedyR is offline   Reply With Quote
Old 22-05-2007, 8:57 PM   #3 (permalink)
Conspicuous Member
thfccambs's Avatar
Thanks: Gave 175, Got 564
Just watched this and it's excellent.top quality picture also.
"It is better to fail aiming high than to succeed aiming low. And we of Spurs have set our sights very high, so high in fact that even failure will have in it an echo of glory."- Sir Bill Nicholson .
thfccambs is offline   Reply With Quote
Old 22-05-2007, 10:23 PM   #4 (permalink)
Thanks: Gave 1, Got 3
You mean that this title(region A) works on region B Playstation3?You sure,where did you get this info?I really wanted to buy this title but since it said region A on the cover i assumed it wouldn't work on my Europena PS3
ramalho is offline   Reply With Quote
Old 23-05-2007, 1:00 AM   #5 (permalink)
SeedyR's Avatar
Listed on movietyme as region free:
http://www.movietyme.com/catalog/def...96bb75186b2ddc
Also been confirmed by other forum members.
Old 23-05-2007, 7:43 AM   #6 (permalink)
RoughNeck666's Avatar
Thanks: Gave 7, Got 130
I have personally tested it and it works on a UK PS3.
If when you get it for some reason it doesn't you can send it back to us.
Postings i make are my own opinions and not that of the company i work for!
RoughNeck666 is offline   Reply With Quote
Old 23-05-2007, 7:43 AM   #7 (permalink)
Thanks: Gave 7, Got 16
Its out i the UK in a couple of weeks anyway.
Monkeyspoon is offline   Reply With Quote
Old 23-05-2007, 9:20 AM   #8 (permalink)
Conspicuous Member
thfccambs's Avatar
I've also just checked my US copy on a UK PS3 and no problems at all.
Like movietymec have reported works fine.
apocalypto, bluray
