02-02-2007, 7:30 PM
#1 (permalink)
| | Senior Member
Thanks: Gave 47, Got 295 | Babel - HD-DVD or Blu Ray?
Paramount have thrown a little bit of a curve ball with this one,
HD-DVD30, AVC, DD+ @640kbps http://hddvd.highdefdigest.com/babel.html
or
BD50, Mpeg2, DD @640kbps http://bluray.highdefdigest.com/babel.html
Reviews say there is no real difference in picture or audio quality. If they had used VC-1 I would have gone for the HD-DVD version, but as it's AVC and the Blu Ray version is a BD50, which one do you get?
02-02-2007, 10:25 PM
#2 (permalink)
| | Member
Thanks: Gave 3, Got 19 | Re: Babel - HD-DVD or Blu Ray? Quote:
Originally Posted by lfletcher | I'd go with whicevers cheaper, probably still go HDDVD simply based on the fact that avc is newer.
04-02-2007, 3:53 PM
#3 (permalink)
| | Distinguished Member
Thanks: Gave 819, Got 1,086 | Re: Babel - HD-DVD or Blu Ray?
Do we have any idea why the change to AVC? Is this a one off or the start of more?
I bought HD DVD but before I knew this stuff based on 'previous' Paramount experiences.
Do everything with excess, even excess
04-02-2007, 5:30 PM
#4 (permalink)
| | Senior Member
Thanks: Gave 47, Got 295 | Re: Babel - HD-DVD or Blu Ray? Quote:
Originally Posted by Nic Rhodes Do we have any idea why the change to AVC? Is this a one off or the start of more?
I bought HD DVD but before I knew this stuff based on 'previous' Paramount experiences. | Similar questions have been asked over on AVS and Amir said that it was the post houses decision to use AVC for this title, rather than a Paramount directive. I'm sure the amount of grain in the title was put down as a reason for using AVC.
04-02-2007, 5:48 PM
#5 (permalink)
| | Senior Member
Join Date: Jan 2006 Location: Edinburgh (the Gorgie Road end)
Thanks: Gave 443, Got 86 | Re: Babel - HD-DVD or Blu Ray?
I've ordered the HDDVD of Babel, but the way the film is filmed and on reviews the picture will be the same on both
__________________ Pioneer Kuro pdp508xd - UK PS3 - Xbox360 Elite - HDDVD - Pioneer DVR-LX60D Recorder - Pioneer VSX-LX60D Amp |
04-02-2007, 5:54 PM
#6 (permalink)
| | Ex Member
Thanks: Gave 138, Got 196 | Re: Babel - HD-DVD or Blu Ray? Quote:
I bought HD DVD but before I knew this stuff based on 'previous' Paramount experiences. | It makes you wonder why they didn't use AVC for both BD and HD. Why go through all the bother of two encodes if the outcome is the same and there's no politics involved?
04-02-2007, 10:48 PM
#7 (permalink)
Why the MPEG2 is used on BD is known, why the change on HD DVD is less 'characterise'd but seems to have been explained by LFs posts.
