24-04-2002, 7:49 PM
#16 (permalink)
Thanks: Gave 6, Got 11
I just ordered the avia one
24-04-2002, 7:53 PM
#17 (permalink)
Thanks: Gave 23, Got 25
You're too easy.
Guy
Onkyo TX-SR875 B&W MT-30 Panasonic 50PH9 PS3 Sky HD
24-04-2002, 7:56 PM
#18 (permalink)
Actually the wife says im like Martini
anytime anywhere anyplace lol
24-04-2002, 7:59 PM
#19 (permalink)
I do like your wife.
Guy
24-04-2002, 8:01 PM
#20 (permalink)
Yours makes great bacon
24-04-2002, 8:05 PM
#21 (permalink)
Only when she's happy. That's why I always get toast.
Guy
26-04-2002, 1:07 PM
#22 (permalink)
Thanks: Gave 11, Got 19
If you order it from EzyDVD, it works out £11.75 delivered (ROE 2.7)!!!!
26-04-2002, 1:15 PM
#23 (permalink)
What is ROE 2.7?
I've already ordered it from DVDBox Office. It was posted today.
I tend to stick with R1 for the prog scan abilities.
Guy
26-04-2002, 1:19 PM
#24 (permalink)
Sorry - still in work mode! ROE is Rate of Exchange!
It doesn't matter where in the world you buy this disc from. They're all identical - region 0 and NTSC.
26-04-2002, 1:21 PM
#25 (permalink)
Didn't know that. Thanks.
As I use the search engine 99% of the time, Ezy aren't one of my selected options. But....I'd bet someone else somewhere would poss have it even a smidge cheaper than that, probably.
Guy
26-04-2002, 7:54 PM
#26 (permalink)
Thanks: Gave 64, Got 27
So will the Ultimate DVD Platinum and Avia pay on region 2 players then?
better to go in a blaze of glory than to fade away
26-04-2002, 9:34 PM
#27 (permalink)
Yes
Are you tomando el pelo?
