Anyone heard anything about the Myth
Old 07-11-2005, 2:23 PM   #1
7,282, Level: 20
Points: 7,282, Level: 20 Points: 7,282, Level: 20 Points: 7,282, Level: 20
Thanks: Gave 4, Got 1
And how does DTS Full Range compare with DTS ,I see there are 2 versions of the Deluxe edition with only £1 difference!
http://www2.cd-wow.com/detail_result...uct_code=22816
http://www2.cd-wow.com/detail_result...uct_code=22911
Old 07-11-2005, 2:28 PM   #2
retired member
21,535, Level: 35
Points: 21,535, Level: 35 Points: 21,535, Level: 35 Points: 21,535, Level: 35
Thanks: Gave 4, Got 217
'Tis on our hitlist for reviews this month (all going well!)
Old 07-11-2005, 2:42 PM   #3
samjpullen's Avatar
10,390, Level: 24
Points: 10,390, Level: 24 Points: 10,390, Level: 24 Points: 10,390, Level: 24
Thanks: Gave 122, Got 145
Hey its only £1 and with a £1 voucher it will be the same price :D
Old 07-11-2005, 2:56 PM   #4
west
Posts: n/a
I was looking into this film on Friday but I couldn't seem to find any decent reviews of the film. By that I mean I could not find out whether the film would be any good or not.
If you're seriously thinking about taking a chance on it there appears to be two versions with the full bit rate DTS soundtrack. The most expensive one limited to 5000 copies and the more reasonably priced one limited to 10,000 copies. Yes Asia are selling , or at least were on Friday, the more reasonably priced one for $20 plus postage and packing... which roughly works out at £14 - £15. Personally I have decided not to take the chance judging by Jackie Chan's most recent films, it's an expensive risk IMO.
Old 07-11-2005, 6:27 PM   #5
4,223, Level: 15
Points: 4,223, Level: 15 Points: 4,223, Level: 15 Points: 4,223, Level: 15
Thanks: Gave 114, Got 60
has this got anything to do with the terracotta warriors?
edit:
Limited Mini Terra-Cotta Figure Excavating by Yourself (##One Of Four Figures)
doh, that'll be a yes then...
This is VERY tempting.
