AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Movies, TV Programmes and Music > Movies and The Cinema
LinkBack Thread Tools Display Modes
Old 20-06-2005, 10:03 AM   #1 (permalink)
The best sounding/picture DVD - No doubt
I have just had my senses truly blown away, by what you may ask?! It is - Jean Michel Jarre: Jarre In China. The picture is filmed in High Definition which is unlike anything I have seen before, amazing I have the Panny PD30 which can scan at 75hz so that obviously helps. The sound in DTS (THX certified) is again awesome, in my view blows away all other DVDs The clarity is so so clear and very loud. Even if you don't like Jarre, get this as this is the best demo material you can use
saucer is offline
Old 20-06-2005, 1:47 PM   #2 (permalink)
Starburst's Avatar
Thanks: Gave 86, Got 631
It was actully shown in HD on EURO1080, live I think which should make even the DVD version look lacking in detail
Last album I bought was the CD/DVD of AERO, excellent audio quality using DTS on the DVD and makes you wonder why they really pushed SACD and DVD-A for so long.
"The Nac Mac Feegle are, well, they’re like tiny little Scottish Smurfs who have seen Braveheart altogether too many times."
Starburst is offline
Old 20-06-2005, 4:22 PM   #3 (permalink)
Thanks: Gave 14, Got 38
saucer
Where did you purchase the DVD from? I did a quick search but nothing came up with that title.
OnTheFly is offline
Old 21-06-2005, 9:55 AM   #4 (permalink)
Tejstar's Avatar
Thanks: Gave 364, Got 900
Try Amazon.
Cd-wow did have it but I can’t see it on their site now!
Tejstar is offline
Old 21-06-2005, 12:26 PM   #5 (permalink)
Conn's Avatar
Thanks: Gave 41, Got 104
It is #11, instore in WHSmiths music DVD chart for £19.99....
Conn is offline
Old 21-06-2005, 1:37 PM   #6 (permalink)
Thanks for that.
OnTheFly is offline
Old 21-06-2005, 2:07 PM   #7 (permalink)
Thanks: Gave 0, Got 6
Play.com = £17.99
http://www.play.com/play247.asp?pa=s...M&title=615565
Skovgaard
Skovgaard is offline
doubt, dvd, sounding or picture
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
