AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Movies, TV Programmes and Music > On Disc and Downloaded > Movie Suppliers and Technology
LinkBack Thread Tools Display Modes
Old 05-11-2007, 11:51 PM   #1 (permalink)
DVD-Man's Avatar
Thanks: Gave 132, Got 156
Anyone know a way to repair dvd case centres on boxsets?
Got a boxset, you know the kind, fold out packaging, clear plastic holder on a carboard background.
The centre is broken on a couple so the discs are loose and I want to stop the scratching, is there anthing that can be done?
Liam
DVD-Man is offline
Old 06-11-2007, 12:33 AM   #2 (permalink)
Thanks: Gave 74, Got 633
Re: Anyone know a way to repair dvd case centres on boxsets?
They are called digipaks. I would use a replacement case to put all the discs in or, just get a couple of those plastic sleeves and put the discs inside to protect them.
nwgarratt is offline
Old 06-11-2007, 12:47 PM   #3 (permalink)
Marc's Avatar
Thanks: Gave 127, Got 286
bit of a stretch, but if you buy some regular dvd cases that use the solid plastic ring method to hold the disc in, you can cut the ring and part of the back of the case off with a stanley knife, and the break off the remaining clips from your digipak and glue the ring in it's place.
or more simply, cut out a nice circle of bubble wrap from a jiffy bag, and put it on top of the dvd, that way when the boxset is shut, the disc will be held in place by the bubble wrap
My almighty DVD/HD-DVD/Blu Ray Collection
MANCHESTER UNITED - PREMIER LEAGUE AND EUROPEAN CHAMPIONS 2007/8
Marc is offline
Old 06-11-2007, 8:53 PM   #4 (permalink)
DVD-Man's Avatar
Thanks guys, I have done the replacement case option in the past but annoyed at the wasted packaging, I may try some butchering yet!
Liam
DVD-Man is offline
boxsets, case, centres, dvd, repair
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
