AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Movies, TV Programmes and Music > On Disc and Downloaded > Movie Suppliers and Technology
LinkBack Thread Tools Display Modes
Old 28-06-2005, 8:01 AM   #1 (permalink)
Thanks: Gave 4, Got 0
Converting R2 to R1
is there any links or sites for codes to convert R2 DVD players to R1 players?
Regards
Pete
mercman1969 is offline
Old 28-06-2005, 8:13 AM   #2 (permalink)
Thanks: Gave 12, Got 595
Try the 'DVD Player Handset Hacks' forum page which isnt far down from this section.
Indiana Jones is offline
Old 28-06-2005, 10:16 AM   #3 (permalink)
Dr Diversity's Avatar
Thanks: Gave 21, Got 16
Regards
Pete
As above for the hacks. You will find they change the player to multiregion so accepting any disks
Dr Diversity is offline
Old 28-06-2005, 5:39 PM   #4 (permalink)
Mep
Mep's Avatar
Thanks: Gave 301, Got 367
some can be converted via teh handset, some require the right firmware installed and other you can buy one use remotes that do the job.....depends what you have
Mep is offline
converting
[IMG] code is Off
Refbacks are On
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
