For twenty years before DVD I collected movies on NTSC Laserdiscs. It was only way to get films etc running at their correct speed ( the advantage of a 60hz video standard )
with rich colour and many letterbox titles with such features as commentary tracks and supplementary programmes. One should note here that the intellectual mindset of commentary tracks has mostly fallen in the mass market DVD age when contrasted to the LD niche market where-in cinema monologue or dialogues tended to be at a higher educated level. Nowadays commentaries are like "Oh yeah! Remember that day when Wardrobe couldn't find the blue socks I needed for the costume?" Okay continuity is relevant for a production but recollections of trivia is not necessarily worth our time listening to.
One great area of exception to dumbed-down discussion on DVD is in the dissident-documentary category. Such titles as THE CORPORATION and CONTROL ROOM and THE FOG OF WAR and LIFE AND DEBT are proof that DVD can in fact go beyond Laserdiscs.
All of these titles are North American produced documentaries. So what type of person would buy them on REGION 2 when the original master is a 60hz NOT a 50hz
master (be it SD or HD) ? The same questions applies to box sets of American TV shows. Why would someone be foolish enough to buy BUFFY THE VAMPIRE SLAYER or FIREFLY in REGION 2 ? As American TV shows posted on a 60hz video format (in the case of BUFFY 30fps NTSC in the case of FIREFLY 24fps High Definition / 30fps playback compatible ) are finalized in a standard that is native to Region 1 DVD and NOT native to European 50hz Region 2. Where is the logic in buying more expensive Region 2 editions that are not authentic? As feature films are shot on either film-stock at 24fps or HD at 24fps there is two ways to experience them played back, running at their native running speed in both cases a 60hz video standard does what 50hz cannot do.
If your DVD player is connected to your TV via say a Y/C aka an S-video lead (or composite phono) then you will be viewing as interlaced video. Perfectly good quality from an R1 disc with the frame rate running at 30fps but the running speed correct as they use what is known as the 3-2 Pulldown to make 24frame film-stock run at the correct speed as a 30frame playback. There is no such adjustment for 25frame PAL. The 60hz of NTSC is what gives NTSC a more stable image over PAL 50hz. The horizontal resolution is the same on both systems while the extra vertical lines on PAL are in fact cancelled out as any kind of advantage by the disadvantage of the following R2 typical characteristics.
R2 especially UK issue.
1. Most DVD's authored by London based firms are authored by people with inferior personal and professional standards. You would be amazed at much the general technical ignorance and lazy and conceited mindset permeates and determines the mediocrity of the UK DVD industry. Yes there are exceptions but the bad is the rule when dealing with British DVD's and the people responsible for them.
2. Another problem with R2 is that those extra vertical lines any advantage of which is cancelled out by crap authoring anyway, leaves far less room for colour on R2 discs. Plus big studio titles often have numerous dub tracks for the Euro market on a single disc. The result is that PAL colour which at the best of times is weak compared to NTSC colour is even worse on R2 discs. In fact a REGION 1 DVD carries DOUBLE the amount of COLOR ENCODING on the disc giving a far richer cinematic pallette.
3. Compare artwork and packaging and most R2 issues look cheap and nasty.
4. The English language subtitling on non-English language films is always better from the NTSC/ATSC market. I found this on NTSC Laserdisc and USA theatrical prints also. This is because American universities have a better track record on teaching languages than UK universities and even highschools also. Plus the Americans write very good dialogue. They tend to retain the lyricism and feeling of the original far better than the kind of technical translations we get over here that tend to kill off the heart and soul in the dialogue. A perfectly good example of this is the movie INDOCHINE across all formats theatrical/TV/Laserdisc/DVD the American subtitling of both the French and Vietnamese dialogue is far superior and has a far greater emotional impact than the cold and unfeeling translation on the UK issues. A major reason why some British cinema critics were cold toward this great French epic while American critics received it with raves. I believe that the difference in subtitles and translation made all the difference.
5. Choice and price on R1 is far better.
6. Here is the bottom line. Let's say you are a fan of THE SOPRANOS. Let's say you have only seen the show on C4 and R2 disc. The show which personally I fell-out of like with a long time ago, but never mind, lots of you still love it, uses regional vocal intonations and phrasing as a key part of its actors characterizations. Running 4% speeded up on 50hz PAL you have never really heard how Tony speaks You are missing the fine nuances of the lingo and expression. I remember a friend of mine way back when getting off-air VHS tapes of STAR TREK sent to him from a friend in Canada. He was immediately struck by the realization that for the first time he was hearing Captain Picard's or Captain Janeway's speaking voices as they are and not as they are misrepresented by the PAL speed-up.
To return to the subject of playing back REGION 1.
The other way to playback REGION 1 is via component 3 phono video lead using a PROGRESSIVE SCAN player.
On appropriate titles you will experience true 24 frame film rate cinema and if you use a projector like TOSHIBA ET1 as I do (with my imported PIONEER DV-656A dvd player moded for multi-region by the nice folks at World Gift Center in Chicago). The results of PROGRESSIVE SCANNING in 24fps/60hz can on a good R1 disc be so breathtaking that I am quite skeptical about what spending the better part of three grand on upgrading to HD is going to do for me. Let me put it this way the planned HD transmissions from SKY in 50hz will NOT be as good as what I have now from REGION 1 SD DVD on my LCD projector. Apart from the speed and colour issues SKY's HD transmissions are going to be subjected to so much compression that they will be self-defeating plus if you watch them on a bloody PLASMA screen it is going to look like mush.
Last but not least here is a tip.
Apart from FIREFLY I have yet to find a TV BOX SET that does not look better and play better with the PROGRESSIVE SCANNING switched OFF!!! This is due to interlaced mastered TV shows being PROG SCAN encoded on disc AFTER the fact. So sometimes one can do better say for example ANGEL by switching the PROG SCAN off (on the front panel of the player if you have a hard switch. Just remember to put it back on before watching a feature film ).
If you want tips on setting up a TOSHIBA ETI projector (and related DVD functions) for best colour results / write me at
hsm_melody@hotmail.com
