Motorola RAZR2 V8
Old 06-12-2007, 7:36 PM   #1
7,697, Level: 20
Points: 7,697, Level: 20 Points: 7,697, Level: 20 Points: 7,697, Level: 20
Activity: 4.1%
Activity: 4.1% Activity: 4.1% Activity: 4.1%
Thanks: Gave 40, Got 53
Motorola RAZR2 V8
Does anyone know if this phone will accept a larger media card and more importantly where does it fit?
(It already has a 512mb fitted as standard)
Old 06-12-2007, 8:20 PM   #2
DELUCAS's Avatar
16,103, Level: 30
Points: 16,103, Level: 30 Points: 16,103, Level: 30 Points: 16,103, Level: 30
Thanks: Gave 42, Got 149
Smile Re: Motorola RAZR2 V8
Hope this helps !! Motorola RAZR 2 V8 Review
11 October 2007
View deals
Specifications Full review Compare Look and FeelThe phone looks fantastic with its glossy metal front finish and two-inch external screen. In truth, it's not too dissimilar to its predecessor, but is 2mm thinner. The V8 has looks slick and, although 55mm wide, it surpasses most handsets and still fits neatly in your palm. A new black and gold model with a snakeskin back will be released in November.
FeaturesThe phone lacks 3G and the two-megapixel camera means the V8 ultimately falls short of some of the more equipped handsets. However, the V8's media player functions - not to mention its phenomenal battery life are big plusses.
Ease of UseEven for a Motorola novice, the V8's navigation is simple, with access to applications broken down into nine main menu headings. When the clamshell is closed and the media player is still in use, the external screen transforms into a touch-screen interface.
PerformanceA solid all-round performer. The V8 is fitted with CrystalTalk technology, that automatically adjusts the audio to ensure calls are clear and crisp, despite any noisy environment you may be in. It's not flawless, but it works well and the voice-activated call function can pick up the command despite any unwanted background noise..
Battery LifeThe V8 offers excellent talktime - almost double that of a great many 'designer' phones on the market.
Motorola RAZR 2 V8
Pros: Motorola has managed to make its RAZR handsets even easier on the eye and the built-in music player is of a high standard. The marathon battery life also deserves a mention
Cons: The V8's mediocre two-megapixel camera and the lack of 3G and a memory card slot is frustrating, to say the least
Battery life
Ease of use
Features
Look and Feel
Performance
Mobile Choise Total Score
Verdict: If style is top of your criteria, then the RAZR 2 V8 won't disappoint, but its features fail to live up to the promise.
top deals for this phone
Handset cost: FREE 18 month contract
Tariff: O2
Supplier: Dial-A-Phone
Buy now |
Handset cost: FREE 12 month contract, 6 Months Half Price
Tariff: O2
Buy now |
Tariff: O2
Buy now | View more deals Back to topThe full Motorola RAZR 2 V8 Review
Following the success of its breakthrough handset, the RAZR V3 (a handset that continues to sell well even today), Motorola has launched its follow-up, the RAZR 2 V8.Even the packaging of the V8 gives you the feeling you're about to experience a well-groomed handset. Once you've pulled the golden ribbon, the V8's box transforms, before popping up to reveal the shiny handset in all its glory.
RAZR sharp looks
The phone looks fantastic with its glossy metal front finish and two-inch external screen. In truth, it's not too dissimilar to its predecessor - although Motorola has managed to make it 2mm thinner - and this is not such a bad thing. The V8 has still got that slick feel we've come to love with the various RAZRs and, although 55mm wide, it surpasses most handsets and still fits neatly in your palm. The V8 is a tough little cookie. The internal frame is made of stainless steel that makes it durable yet relatively light at 117g. And the exterior screen is made with chemically hardened glass, which is incredibly scratch resistant. Given its appealing shine, the handset is susceptible to grubby fingerprints on both the screen and the exterior.
Easy mobile navigation
Even for a Motorola novice, the V8's navigation is simple, with access to applications broken down into nine main menu headings. However, after a good half hour of searching, we can conclude that the IM Messenger function is not found on the V8, despite the phone's manual saying otherwise. Tut-tut, Motorola. Like most handsets, the V8 features a speed dial option, that allows you to store up to nine pre-set numbers, which can be activated with a single key. The V8 is fitted with CrystalTalk technology, that automatically adjusts the audio to ensure calls are clear and crisp, despite any noisy environment you may be in. It's not flawless, but it works well and the voice-activated call function can pick up the command despite any unwanted background noise..
Bluetooth your pics
Where the V8 disappoints is with its feature set. The phone lacks 3G and the two-megapixel camera means the V8 ultimately falls short of some of the more equipped handsets. The camera itself has a multi-shot facility, that allows you to take up to eight consecutive pictures, while it is also possible to send a photo from your handset direct to a Bluetooth-enabled printer. The video recorder allows up to two hours of recording time, as well as a playback option.We were also disappointed to find that the V8 only has one micro-USB port, which meant we were unable to use the handsfree kit and charge the phone at the same time. It also means you can't plug the USB cable into your PC while listening to your music through your headphones. There are, however, some impressive features. The V8's media player functions - not to mention its phenomenal battery life - may be why some have mentioned the phone in the same breath as the Nokia N95 and the Apple iPhone. Motorola has enabled its handset to support Windows Media Player 11, which allows you to purchase, synchronise and transfer your music library to your phone in a matter of minutes..
Size zero model
The V8 can be bought with 2GB of removable memory, that should give you room for approximately 1,000 songs. If building up a mini-jukebox isn't your thing, then the V8 is available with just 420MB internal memory. A new black and gold 2GB model with a snakeskin back will be released in November. By using a high-speed USB 2.0 connection, it should be possible to transfer 1,000 songs in about 30 minutes. The music quality is impressive, yet this is balanced out by the disappointing lack of an expandable memory card slot - a sacrifice that Motorola is perhaps willing to make to ensure its phone remains a size zero model. When the clamshell is closed and the media player is still in use, the external screen transforms into a touch-screen interface. You can rewind, pause or skip tracks by touching the screen and as a nice little touch, Motorola has included a vibrating response to any command you place..
Easy texting
The exterior screen also comes into play when you receive a text message. You can read your texts without having to open the clamshell by using the side keys. What's more, Motorola has included a number of quick replies, so you can reply to a text without having to open the handset. You can also create your own pre-set messages. It's worth noting that with the phone closed, you can only reply to a text; you are unable to create a new message without flipping it open and going through the usual process.As well as the ability to sync your music, the V8 also comes with an installation CD that allows you to synchronize your data, contacts and emails from your PC to your handset with Motorola's very own Motosync. This can be activated through the accompanying USB cable, infrared or Bluetooth. It's a useful tool when you're on the move and away from the office, but the initial installation process can be somewhat tedious.
Lack of 3G
As the name, not to mention the impressive advertising campaign, suggests, the RAZR 2 V8 is a sharp-looking handset and wouldn't look out of place next to any fashion phone. The media player is great, although it's hard to ignore the lack of an expandable memory card slot. Ultimately, with its lack of 3G and only a two-megapixel camera, the RAZR 2 V8 falls into the mid range of the market. As the saying goes, looks aren't everything.
Back to topSpecifications
Audio playback: MP3/AAC/AAC+
Camera: Two megapixels
Connectivity: Bluetooth, USB, A2DP
Display 2.2-inch TFT, 256,000 colours; external: Two-inch, 256,000 colours
Email client: POP3, SMTP, IMAP4
Frequency: Quad-band
GPRS: Yes + EDGE
Games: Football, Sudoku
Internal memory: 420MB or 2GB
Internet browser: WAP/xHTML/HTML (Opera 8.5)
Java: Yes
Memory card slot: No
Messaging: SMS, EMS, MMS
Radio: No
Resolution: 240x320 pixels
Ringtones: Polyphonic, MP3
Talktime: 500 minutes
Video calling: No
Video recording / playback / streaming: Yes/yes/yes
Weight: 117g
search for deals
Manufacturer
please select... Sony Ericsson Samsung Nokia LG Motorola BlackBerry O2 Any
Phone model
please select... BlackBerry 8800 LG KE850 Prada LG KE970 Shine LG KU990 Viewty Motorola KRZR K1 MOTOKRZR K1 MOTORIZR Z8 Motorola RAZR 2 V8 Motorola RIZR Z8 Motorola W220 Nokia 5300 Nokia 6110 Navigator Nokia 6111 Nokia 6120 Nokia 6280 Nokia 6300 Nokia 6500 Classic Nokia 7373 Nokia 8600 Luna Nokia E65 Nokia E90 Communicator Nokia N73 Nokia N81 Nokia N81 8GB Nokia N91 Nokia N95 Nokia N95 8GB O2 Xda Orbit Samsung D840 Samsung D900 Samsung E900 Samsung F210 Samsung F300 Samsung G600 Samsung G800 Samsung J600 Samsung U600 Samsung X830 Sony Ericsson K610i Sony Ericsson K770i Sony Ericsson K800i Sony Ericsson K810i Sony Ericsson K850i Sony Ericsson P1i Sony Ericsson S500i Sony Ericsson W660i Sony Ericsson W810i Sony Ericsson W850i Sony Ericsson W880i Sony Ericsson W910i Sony Ericsson W950i Sony Ericsson Z610i Any
Tariff type
please select... Contract Any
most popular reviews
Apple iPhone
Sony Ericsson K850i
Sony Ericsson W910i
Nokia 6300
Nokia N95
Samsung G600
Nokia 8600 Luna
LG KU990 Viewty
Nokia N81 8GB
Samsung U700V
OnTheFly (07-12-2007)
Powered by
 Latest popular product prices
Motorola WX160
1 price
 £12.99 Click to show/hide the offers
Motorola Wilder
1 price
 £52.99 Click to show/hide the offers
Motorola Gleam
1 price
 £110.00 Click to show/hide the offers
Motorola Fire
1 price
 £149.99 Click to show/hide the offers
Motorola MILESTONE 2
1 price
 £199.99 Click to show/hide the offers
Motorola Defy
3 prices from
 £217.00 Click to show/hide the offers
Motorola Pro +
1 price
 £297.17 Click to show/hide the offers
Motorola PRO
1 price
 £299.99 Click to show/hide the offers
 Updated February 13th at 10:30am. Prices include delivery.
