something like dust under V3 RAZR screen
Old 04-03-2006, 9:57 PM   #1
Ado9
Posts: n/a
When the screen is black, the spots appear white, but when the backlight is on the spots are black... what can i do? is there a way to take off the screen
Old 04-03-2006, 11:30 PM   #2
Thanks: Gave 5, Got 72
http://www.uselessinfo.pwp.blueyonde...ismantlev3.htm
Old 05-03-2006, 12:38 AM   #3
Ado9
Posts: n/a
Is there an easier way?
because if i have to do all of that i have a feeling ill break it in the first step
LOL... well can i just take off the screwcaps by the screen and do it that way?
Old 05-03-2006, 11:16 AM   #4
yes- you only need to start at the step 10 bit
Old 06-03-2006, 9:00 PM   #5
Thanks: Gave 7, Got 6
I have just started a thread with same question... How did this dust go in there in first place?????? can I call motorola with this and will they be of any help??? My phone is only a few months old
gaurav
Old 06-03-2006, 11:05 PM   #6
Originally Posted by drguptagaurav
gaurav
ive seen this on a few now - it must get in through the speaker holes or the edge gaps, drawn onto the screen by static maybe?
Old 07-03-2006, 1:14 AM   #7
Ado9
Posts: n/a
There used to be just a couple of little dots that were barely noticeable when the backilght was on, but now a really big spot appeared under the screen and im really mad! can i kall motorola or cingular and ask them what i can do, or shud i return it since i have a warranty thats still good?
Old 07-03-2006, 10:24 PM   #8
RandomLee's Avatar
Thanks: Gave 897, Got 501
Are you sure it's not dead / stuck pixels? Or is it deffo dust?
Speaking of dust, my K750i was full of it after a week or 2... I doubted SE would take it seriously as a problem so I didnt bother to do anything about it.
Old 08-03-2006, 2:53 PM   #9
Ado9
Posts: n/a
I'm really not sure what it is, i think its dead pixels though but im not 100 percent sure, anyway, can any1 help?
Old 08-03-2006, 4:06 PM   #10
RandomLee's Avatar
If it's dead pixels then warranty it... that's a fault with the screen and a definate warranty claim. I am on my 2nd PSP for that very reason.
If it is dust then to be honest I reckon you'll just have to live with it as I cant imagine they will do anything about that.
Check with them though, you never know. It's always best to go the offical route 1st before to get the T6 out and open it up...
I doesnt sound like dust to me though.
Old 08-03-2006, 8:42 PM   #11
/////AMG's Avatar
Thanks: Gave 43, Got 32
It has to be dust. I have a few friends with this phone and they have the eact same problem.
Old 08-03-2006, 9:51 PM   #12
monkeynuts's Avatar
Thanks: Gave 17, Got 25
Try working on a building site and see how phones last!
The older more robust ones were definitely better sealed, and the nokia's with express-on covers made cleaning a doddle!
