According to
Crucial Memory website your motherboard can take the following RAM:
Memory Type: DDR3 PC3-10600, DDR3 PC3-8500, DDR3 PC3-12800, DDR3 (non-ECC)
Maximum Memory: 8GB
Slots: 4
Each memory slot can hold DDR3 PC3-10600, DDR3 PC3-8500, DDR3 PC3-12800 with a maximum of 2GB per slot
Note that it states '
maximum of 2GB per slot' so if the RAM you have found is 2x 4Gb then it wont go in this PC.
Also if you are running a 32bit version of Windows then anything over 4Gb in total will be ignored as it will only be able to address a max of 4Gb. For 8Gb to be usable you need to have a 64bit version of Windows.
Mark.
