Which mobo ?
Old 14-06-2012, 1:58 PM   #1
Thanks: Gave 0, Got 2
Which mobo ?
Yep another one of these threads.
My budgest is £120 max.
I'm buying an i5, already have an SSD, will buy some memory and I'm looking to utilise onboard graphics for the time being (I'm not going to be gaming).
I think these are the options:
Gigabyte GA-Z77X-UD3H Socket
ASRock Z77 Extreme4-M
Asus P8Z77-V LE
Asus P8Z77-M Pro
I'm leaning towards Asus because I have previously bought from them but the gigabyte card looks very similar to the Asus LE and both the Asus look comparable.
I can only see me adding a graphics card in future to handle 3D output to a LCD and possibly some additional HDD drives.
Any thoughts or others to consider ?
Old 14-06-2012, 4:18 PM   #2
rojgelf's Avatar
Thanks: Gave 420, Got 1,144
Which i5 are you buying, one with HD2000 / 3000 or the new ivy bridge with I think HD4000 graphics, if the latter make sure your board supports HD4000 graphics (I think all the Z77's should), this will obviously give you the best onboard graphics experience.
I also prefer asus and I would get the M Pro over the V LE. Can't see why an MATX board wouldn't be sufficient, there are plenty of nice MATX cases now which will save space and provide sufficient cooling.
For £25 less the P8Z77-M looks pretty good too:
http://www.ebuyer.com/363737-asus-p8...rboard-p8z77-m
Old 14-06-2012, 5:07 PM   #3
An MATX is probably sufficient but I'm looking at getting a Silverstone LC13 case which can house both MATX and ATX, the only difference I can see between the two Asus mobos is that the LE has an additional Sata III connection which may be useful further down the line.
The P8Z77-M only has 2 onbaord USB 3 ports (as well as the above) and is only about £20-30 cheaper which isn't a big deal to me so I'm thinking the LE is the one to go for.
Old 16-06-2012, 10:57 AM   #4
Thanks: Gave 203, Got 326
Down to preference.
I have gigabytes in my systems. My media PC has a E8400 with gigabyte board. Must be about 5-6 years old now
