Reccomend a quiet i2500k cooler
Old 08-06-2012, 8:59 PM   #1
Thanks: Gave 5, Got 14
Hi, just ordering bits for a new build. Using a 2500k and a z77 mATX mobo.
I'm after something very quiet as will be using this to work on at home.
Any recommendations for a decent cooler under £30?
Old 08-06-2012, 9:09 PM   #2
Thanks: Gave 335, Got 1,917
The Cooler Master Hyper 212 Evo is a good choice for around 30 quid.
Old 09-06-2012, 5:26 AM   #3
Cheers will take a look at that.
I have found the antec and corsair water cooling units that are had for about £45.
Does anyone know if these are any good?
I'm assuming their good at cooling but are they much quieter than a heat sink and fan??
Old 09-06-2012, 9:07 AM   #4
Thanks: Gave 26, Got 93
The i30 is one of the most quiet ones and does a great job too. As is the Pro 13 from the same company.
Old 09-06-2012, 7:26 PM   #5
Went for the i30 as seen a cheap deal. Thanks for the help!
