| Rampage 11 extreme pci-e v1.1
I would like to install a sata3 pci-e card, as this board only supports sata11.
I have been reading posts explaining to install one of these cards your pci-e should be above pci-e v1.1.
This is from the Rampage 11 extreme spec.
Expansion Slots 3 x PCIe 2.0 x16 support at x16, x8, x8, or dual x16 speed
2 x PCIe 2.0 x1 ( the PCIEx1_1 (black) is compatible with audio slot)
1 x PCI 2.2
I have seen posts where pci-e slot 2 should be used, out of the above spec are the pci-e slots on this board v1.1 ?
Also by buying a cheaper sata3 pci-e card will the readings be slower.?
Any help please.
Thank you
Gary.
