Upgrade to i3-530?
Old 25-05-2012, 11:10 AM   #1
Thanks: Gave 29, Got 61
Upgrade to i3-530?
Currently have a i3-530 installed and I'm looking for bit more umph - often get warnings that CPU is maxed out - online gaming, backing up dvd's etc. Current spec is -
i3-530 2.93ghz - stable overclock to 4.2ghz
4GB DDR3
ATI 6970 (running 3x23" monitors - sammy md230x3)
OS & Apps on SSD
Looking at upgrading to a i5-650 3.2ghz, I assume I'll be able to overclock to a degree obviously the quad core will help as well - good move / bad move?
Old 25-05-2012, 2:26 PM   #2
LJx LJx is offline
LJx's Avatar
Thanks: Gave 39, Got 353
I would say bad move because it is two generations old and you can get much better performance from ivybridge / Sandy Bridge processors, you would just need a new motherboard
Old 25-05-2012, 2:33 PM   #3
OK, but that would mean a motherboard and cpu upgrade... limited funds
Old 25-05-2012, 2:53 PM   #4
Thanks: Gave 12, Got 52
You're looking at about £120 for that CPU. Will your motherboard support it?
A quad core will be harder to overclock, more cores=more heat. Also will your software actually make use of the additional cores, if it won't then there's not much point.
As LJx says moving to a more modern platform would see a bigger increase, but as a stopgap it might make sense.
Old 25-05-2012, 4:03 PM   #5
I've checked and the motherboard will support it, yes. Thanks for the advice guys.
Old 26-05-2012, 11:41 PM   #6
Thanks: Gave 23, Got 1,036
That sounds odd, what's giving you the warnings?
All CPUs will operate at maximum on things like games that are set up to use everything that's available, don't expect the i5 to hover at 90% during games, that'll be at 100% too.
Only things with a fixed amount of work to do in each time interval (e.g. playing back a pre-recorded video) are going to use less than 100%.
I wouldn't bother with the upgrade personally, the difference between the two processors isn't much, 10% or so: Giant roundup: 168 Intel and AMD processors! (page 14: Average) - BeHardware
