I completed this build a couple of days ago and am having problems when it is on full load
Setup is
I7 2600k 3.4 (stock cooler)
Asus p8z68-v pro/gen3 with latest bios
750w psu
N560gtx-ti twin frozr 2 graphics card
1tb sata hard drive
8 gig ddr3 1600 ram
When idle (just running programs that windows starts) I get temps of 35 to 40 c room the pc is in is warm
When on full load using prime 95 the temp shoots up to 98c
When prime 95 is stopped it takes around 30 seconds for the temperature to return to 35 to 40 c
The fan is seated correctly with all four plastic pins locked in place (has been reseated once with artic silver 5 applied cpu and fan where cleaned before reaplying)
Any suggestions would be greatly appreciated.
when idle
under load
