Sandy Brige Motherboard
Old 07-02-2011, 10:12 AM   #31
Eminent Member
Tejstar's Avatar
Thanks: Gave 410, Got 1,014
Originally Posted by haker View Post
Have those of you who have had motherboards recalled get on? Have replacements been sent out? I looking for a sandybridge motherboard but nothing availble as of now. Called Ebuyer, I was informed that I should try again in a few days.
Don't expect any new mobos until April, at the point the manufacturers will swap your old mobo for a new one with the B3 chipset.
Old 09-02-2011, 4:25 PM   #32
Sickens me, i have to wait now to build new pc
Old 18-02-2011, 8:25 AM   #33
you could buy one now and replace it when FOC when new ones come out
Old 19-02-2011, 1:54 PM   #34
Thanks: Gave 13, Got 0
Originally Posted by Bazsounds View Post
The flaw ONLY manifests in the 3Gbs SATA ports. ESATA and 6Gbs ports are unaffected. Moving all devices to 6Gbs ports avoids the issue all together
Can I connect 3Gbs SATA connections to the 6Gbs SATA port?
Old 19-02-2011, 2:05 PM   #35
yes you can, thats exactly what I have done
omskie (20-02-2011)
Old 19-02-2011, 2:08 PM   #36
Do you need an adaptor for it? Or can you use the same cable?
Old 19-02-2011, 3:13 PM   #37
coalfield's Avatar
Thanks: Gave 75, Got 19
You can use a regular sata2 cable. They are backwards compatible.
omskie (20-02-2011)
Old 20-02-2011, 6:47 PM   #38
Right. Thanks for that. I'm holding back on building a new pc because of this issue but it's nice to know that I can use the 6Gbs port for older components.
Old 28-02-2011, 4:15 PM   #39
Thanks: Gave 38, Got 17
For those guys who have a Sandybridge Gigabyte motherboard, be sure to register it here, to ensure a replacement is issued.
Further details on how the recall/replacement will take place will be released later.
Old 28-02-2011, 8:42 PM   #40
SirStuie's Avatar
Thanks: Gave 2, Got 2
Any further news on what Asus are doing? TBH I think I will wait until the Z67 motherboards are out and pay the difference with the retailer.
Old 28-02-2011, 10:52 PM   #41
Assured Advertiser
graham.myers's Avatar
Thanks: Gave 219, Got 877
tbh I've always been a fan of ASUS (most of the machines I have built in the last few years have been asus based) but I am tending towards giga recently due to the x67 dabacle. I understand its Intel's fault, but even so, Giga tend to be more "consumer friendly" in the current fun and games. It also differentiates the current retailers on how they want to play things. When it comes to building machines for the end user it boils down to how the OEM wants to treat you.
If you buy from say Scan, and its a ASUS motherboard and its a hassle to get a replacement, is it Scan's fault or ASUS (or Gigabyte, or MSI, or whoever)? It tends to be the retailer who gets the pain as they're at the front end. I do feel for the retailer sometimes. Been there, done that! Even so, small custom builders like myself have to be uber careful. It hits us too!
Thankfully, as I'm a bit niche, my current customers want to wait for the new Sandybridge rather than buying now and expect a replacement. Yes you have to wait a couple of months, but surely that's worth the wait!
Old 08-03-2011, 4:07 AM   #42
Thanks: Gave 23, Got 10
Don't really want to start a new thread on this since im having the saying troubles RE: Picking a motherboard for the i5 2500k that I will be building my PC around. I've been told to go for the P67, even though i don't know the actual reason behind it. All the issues with Sandybridges will blowover by the time it comes to buying mine so I just need to pick one and wait a month or so.
What i really wan't to know is what the best motherboard possible is for the i5. Is there a clearcut difference between first and second or just down to choice? The same 3/4 motherboards are being recommended to me but the difference between them is little so is just down to personal choice after that? Very hard to decide as they all have the basic stuff you want from the motherboard. Any help would be appreciated.
Old 08-03-2011, 2:34 PM   #43
SirStuie's Avatar
If your getting a K model then you need a P67 chipset to overclock it. Its worth the premium as I haven't seen an overclock that doesn't offer a sizeable increase.
There is no clear difference between models other than the added features (Sli, More 6GB Sata ports, etc) so I would not hesitate to get a cheaper model if it fulfils your requirements.
As to which brand I can only say that Asus has been good with the firmware updates that have fixed all the problems I have had and I would imagine that is the same for the other producers as well.
Old 08-03-2011, 11:00 PM   #44
Yeah Asus have been mentioned a lot, even when i was going to get an AMD processor. I knew the K was for an unlocked processor so that it could be overclocked, didn't know the motherboard needed to be specific either so thanks for clearing that up, i will definitely be overclocking. I only plan on getting one small size SSD for the OS which i can use for the 6GB SATA to fully benefit. I guess SLI would be good to have as in case i ever utilise it but i doubt i have them money. I will be spending a lot on the graphics card but not buying two, so that's one thing i can skip if need be. Thanks for the help! Will probably go for the Asus P8P67 Pro or Deluxe, something along those lines.
Edit: Why is this for example so expensive when the only difference i see is having more USB 3.0 ports(10) and less of the 2.0s(8).
http://www.overclockers.co.uk/showpr...-327-GI&tool=5
Cheaper option, essentially the same?
http://www.overclockers.co.uk/showpr...-433-AS&tool=5
It can't be just because of the B3 thing can it?
Old 10-03-2011, 7:51 PM   #45
SirStuie's Avatar
One is a top end mb which can do quad graphics, the other dual. I think the Asus equivalent of that would the Maximus which is about the same price.
Old 11-03-2011, 11:38 PM   #46
Thanks: Gave 0, Got 2
Originally Posted by zAndy1 View Post
Don't know if it helps but you can get 20% off the MSI board if you buy it before the end of the week by claiming the VAT back:-
MSI P67 Get your VAT back promotion!
Is there any VAT promotion available now?I am going to get a P67-B3.
Old 24-03-2011, 4:16 PM   #47
surfury's Avatar
Thanks: Gave 124, Got 58
Well as I posted elsewhere my MSi P67A-GD65 has been replaced by a B3 stepping board less than 24 hours after authorising PayPal. Admittedly MSi are very close (Hayes/Uxbridge) and I was only Invoice 0020 but still pretty quick. I can install it in my own time and they also pay for the CityLink collection (as well as the delivery). Just have to remember to get the old board back to them.
Old 24-03-2011, 6:10 PM   #48
Just to say Gigabyte have contacted me and there is a collect and deliver organised for tomorrow. I give them the old one and get the new one. No money exchanges hands, but its a bit of a rush to backup and remove.
Old 24-03-2011, 9:32 PM   #49
Did not know MSI were in Uxbridge! Live down there for uni.
Old 24-03-2011, 10:23 PM   #50
surfury's Avatar
They're in Hayes, I'm in Uxbridge, well near it.
I got 30 days after receipt.
Old 24-03-2011, 10:45 PM   #51
SirStuie's Avatar
Bloody hell I feel bad for getting an Asus. They won't replace it until its been collected with a 7-10 day turn around
Old 25-03-2011, 3:34 PM   #52
surfury's Avatar
I specifically asked MSi if they wanted all the bits back and they said no just the board. Please don't quote me on this but ring them yourselves as appropriate and if you get themae answer well that's locking 4xSATA 3 cables (I thought was only 3 in original box), SATA/Molex adapter, another SLI cable and USB3.0 backplate (which will go back).
Old 03-04-2011, 8:08 AM   #53
Eminent Member
dejongj's Avatar
Thanks: Gave 2,074, Got 2,735
I took delivery of an asus sabertooth p67 on Friday :-) well pleased with it, and that efi bios is something else. Very stable on my soak test as a hackintosh, so let oc games begin :-)
Old 03-04-2011, 8:31 PM   #54
TNA TNA is offline
What is the difference between the pro and sabertooth? is one better for overclocking over the other?
Old 03-04-2011, 8:35 PM   #55
Eminent Member
dejongj's Avatar
Pro is ugly and Sabertooth is pretty with higher quality components ;-) !!??
TBH I don't know never looked into it, Sabertooth looks good though :-)
Old 05-04-2011, 2:56 PM   #56
Is the sabertooth the B3 chipset?
Old 05-04-2011, 2:57 PM   #57
oh, and can I use SATAIII hard drives with it?
(sorry, quite new to this)
Old 05-04-2011, 3:10 PM   #58
Eminent Member
dejongj's Avatar
yes to both.
Old 05-04-2011, 3:55 PM   #59
I was looking at Asus P8P67-M PRO Rev3 Intel P67 Express Socket 1155 Motherboard instead of the Sabertooth one as it is 50 quid cheaper. What's the difference between DDR 1866 and DDR 2200? Does it really matter? Just wondered why the Sabertooth is so much more??
Old 05-04-2011, 4:54 PM   #60
Eminent Member
dejongj's Avatar
because you are comparing a micro-atx with a full atx board. I cant look up the specs but I suspect there is quite a difference between available ports and expansion capability. The price difference between the normal pro and sabertooth is much smaller.
