AVForums.com twitter AVForums reviewers are ISF Certified.  Click for more information. AVForums is a member of CEDIA.
AVForums.com is the UK's biggest & best home consumer electronics discussion resource
Go Back   AVForums.com > Computers > Motherboards, CPUs, Cases and PSUs
Notices
Are these pc specs good for gaming? adey1986 PC Games 22 17-04-2007 8:27 PM
Gaming specs good enough? skydive Computer Systems 21 23-11-2006 2:30 PM
Wii Specs - UbiSoft Paris Interview Gives Glimpse Of Wii Specs ash Wii 11 02-06-2006 10:00 PM
Old 28-06-2008, 11:47 AM   #1 (permalink)
best gaming motherboard for these specs?
Hi, i'm looking for the best gaming motherboard, but so i can support these specs with the best effiency:
Intel 2 Quad core Q6600 (So i can overclock)
Nvidia 8800 GTX DDR3 768
3GB RAM
Windows vista home premium
A fairly good sound quality thing
730W power (I know an 8800GTX says it needs more, but it works with 525W)
any other specs you need to know, please aks. Thanks
roadrunner021 is offline   Reply With Quote
Old 28-06-2008, 2:00 PM   #2 (permalink)
Thanks: Gave 1, Got 321
Re: best gaming motherboard for these specs?
Do you already have those components? There are better cards than the 8800GTX around now.
Do you want a motherboard that support SLI or would you be fine using one without it?
EndlessWaves is offline   Reply With Quote
Old 28-06-2008, 2:35 PM   #3 (permalink)
namuk's Avatar
Thanks: Gave 172, Got 725
if your not into sli and your going to overclock . an x48 motherboard is the one
Onkyo TXSR875B . BD30. XE1. Tannoy rC. Monolith-DF. AE Aegis One. AE Aegis Three
PC-GA-X38-DQ6. Intel Q6600 3.2 Ghz 4gb Ocz Reaper. GTX 280 .Prelude xfi. 1TB RE3.1TB Black .500GB RE2.2X Raptors .Vista Ultimate. Enermax 1000 DXX. AlphaLCD External.Stacker 830
namuk is online now   Reply With Quote
Old 28-06-2008, 9:16 PM   #4 (permalink)
Those are my current specs, but while i'm at it, i have my old Graphics Card (8500GT) So is it possible and a good idea to run SLi with the 8800GTX and 8500GT? If not, no, i'm not gunna use sli.
Old 28-06-2008, 11:36 PM   #5 (permalink)
namuk's Avatar
no you need 2x 8500 or 2x 8800 you can not mix differant models
storm20200 (01-07-2008)
Old 29-06-2008, 12:23 AM   #6 (permalink)
Thanks: Gave 38, Got 250
And 2x 8500's wouldn't even match the single 8800GTX.
Gigabyte P35 DS3R would do fine but others are available that have newer chipsets.
Miss Chief is offline   Reply With Quote
gaming, motherboard, specs
