AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Motherboards, CPUs, Cases and PSUs
LinkBack Thread Tools Display Modes
Old 26-11-2007, 8:54 PM   #1 (permalink)
Thanks: Gave 5, Got 7
cpu bottleneck?
I have a E6300 @ 1.86,will this be a bottleneck alongside
8800gts 640mb
3gb ddr2 667
Would you upgrade the cpu?
also is my 550w psu powerful enough?
Col
2nd Coming is offline
Old 27-11-2007, 8:37 AM   #2 (permalink)
AML
AML's Avatar
Thanks: Gave 81, Got 128
Re: cpu bottleneck?
I think it depends on what you plan to use your PC for. If its for something intensive like say gaming then yes, it may become a bottleneck.
You could change it for a faster dual or quad core chip or try to over clock your current chip to maybe 2.6ghz or so. Thats a 1000mhz over clock though so it might not work.
Although I was able to over clock my dual core opteron from 1.8 to 2.6 and it was stable for a long time.
Gear: Epson EMP-TW1000 (1080p), Onkyo 805,
PS3 @ 1080p. 360 @ 1080p
PC:Q6600 @ 3.0ghz, 8800GTX
AML is offline
Old 27-11-2007, 9:14 AM   #3 (permalink)
Re: cpu bottleneck?
Thanks AML,yeh i am gaming on a dell 1920 x 1200 so it looks like another upgrade happening soon.
although it is very smooth,i want to turn more effects up in Crysis
If i was to swap it for a q6600 ,which psu should i go for?
Old 27-11-2007, 9:40 AM   #4 (permalink)
Re: cpu bottleneck?
I may try my 1st overclock though
would i notice a difference if took the cpu to say 2.0 or 2.2,which i should be able to do (only done 10 mins research)
Old 27-11-2007, 10:38 AM   #5 (permalink)
Thanks: Gave 26, Got 227
Re: cpu bottleneck?
crysis bottleneck will be the GPU, and yours is pretty beefy. the CPU pretty much does the physics and not much else, although it helps to have a faster one (of course)
i've noticed my quad core rarely gets a thorough workout (2.4Ghz x 4), not nearly as much as other games
and on your final question, I have a 520W Corsair PSU supplying no less than 3 optical drives, 2 hard drives, an x1950pro and a quad core, along with the usual extras. I wouldn't worry about upgrading the PSU
with a system like yours, I'd be inclined to pick up a quicker CPU anyway, as mulitple cores are silly cheap at the moment and it's really not a huge investment for inevitably more performance
insomniak123 is offline
Old 27-11-2007, 11:14 AM   #6 (permalink)
Re: cpu bottleneck?
Thanks insomniak123,added to my ever expanding xmas list from mrs 2nd coming
p.s would the quad core be a simple swap over like for like?
Old 27-11-2007, 11:38 AM   #7 (permalink)
Re: cpu bottleneck?
I'd feel safer saying yes if I knew your motherboard model no, but I'm pretty sure if it holds an E6300 dual core at the mo, it should in theory swap over with a quad core Q6600 or similar without any problems
Old 27-11-2007, 11:53 AM   #8 (permalink)
Razor's Avatar
Thanks: Gave 404, Got 786
Re: cpu bottleneck?
8800gts 640mb
3gb ddr2 667
Col
Overclock your cpu to 2.8-3.0Ghz. Its very easy to do with the C2D. If you have some spare cash buy a Q6600 Go Stepping cpu. They are cheap for the performance they give. Also allot of new games are using all four cores.
Here is a good link for overclocking conroe cpus.
http://www.sharkyforums.com/showthread.php?t=300298
Your psu is more than fine for a quad core or dual core setup.
Click for AV Pics & Spec
70" 1080p SXRD & Watercooled Quad Core HTPC
- Pio AX4ASi-S, Sky HD, 360 Elite, 360 Prem, PS3, Bose AM15, NevoSL Games PC 24" Dell 2407 A04, Asus P5K Premium, Q6600Go@3.0Ghz, 4Gb 1066Mhz, 8800GTX, 620W Corsair, Thermalright 120 Ultra Ex, Akasa Eclipse, X-fi, MX Rev, Vista
Razor is offline
Old 27-11-2007, 12:44 PM   #9 (permalink)
Re: cpu bottleneck?
Asus p5ld2-se motherboard ,sorry should have said.
Thanks lads and thanks for the link,gonna do some research
Old 27-11-2007, 2:40 PM   #10 (permalink)
wormvortex's Avatar
Thanks: Gave 28, Got 80
Re: cpu bottleneck?
what game uses all 4 cores?
The one with the most albums when you die, wins
wormvortex is offline
Old 27-11-2007, 5:15 PM   #11 (permalink)
Razor's Avatar
Re: cpu bottleneck?
Crysis
Medal of Honour Airbourne
Call of Duty 4
Bioshock
Lost Planet
Gears of War
Unreal Tournament 3
These are the games that I own which use all 4 cores.
You also have Supreme Commander and I am sure many others. I havent checked to see if Time shift uses all four cores.
Quad core cpus have been with us for over a year now so its not surprising to see new games take advantage of this.
Razor is offline
Old 27-11-2007, 6:37 PM   #12 (permalink)
Thanks: Gave 2, Got 28
Re: cpu bottleneck?
hi
overclock that cpu to around 2.4 - 3.0, you can find some good overclocking guides for e6300 on google and overclockers forums.
that chip (same as mine) is a notorious overclocker and should last u a little while longer just make sure your cpu / case cooling is up to the job ..apart from that enjoy your new speed
C2D E8400 3 gig @ stock --Zalman 9700 cooler --ATI 4870 -- 2gb corsair pc6400 ram -- Gigabyte DS5-x38 -- 550W+ psu -- Win xp pro .
Dragy2k is offline
Old 28-11-2007, 12:18 PM   #13 (permalink)
AML
AML's Avatar
Re: cpu bottleneck?
I recently got a Q6600 and over clocked it to 2.8ghz. Its nice and stable and all the games (mentioned above) run really smoothe.
(But then I also have a 8800GTX )
As was mentioned a lot of newer games do indeed use all 4 cores so you cant go wrong with a chip like the Q6600. Its nice and cheap and it over clocks really well.
At the end of the year/begining of next year we will see newer 45nm Native quad core chips from intel, but i think it wont peroform that much better than the current non-native quad cores (ie. 2 dual cores stuck together). So theres not much point in waiting.
If your mobo can take it, an upgrade to a Q6600 is a good choice.
AML is offline
Old 28-11-2007, 12:48 PM   #14 (permalink)
Razor's Avatar
Re: cpu bottleneck?
Great little cpus are they AML.
Razor is offline
Old 28-11-2007, 5:57 PM   #15 (permalink)
wormvortex's Avatar
Re: cpu bottleneck?
you should be able to push it to 3.0ghz. I managed it without even touching the volts and it ran prime95 overnight with no issues and the temp not exceeding 48degrees
bottleneck, cpu
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Panasonic BL-PA100A | Bottleneck? twobells Networking 2 29-09-2007 11:47 AM
Help! What's my bottleneck? Upgrade advice needed. Jedfordski Computer Systems 7 18-09-2007 12:26 AM
Bottleneck for internet connection kyleseager Networking 5 23-07-2007 3:40 PM
bottleneck question - GPU or CPU darkeeboy Motherboards, CPUs, Cases and PSUs 2 10-12-2006 11:07 AM
How Can I Confirm The Bottleneck Home PC Nut Computer Systems 12 12-09-2002 8:16 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
