Re: Asus p5k-vm wrong cpu temp
in the bios and software. googling say's that it's a bios problem the new core 2 duo's have a different temerature range (T junction) up from 85 degrees c on the old chips to 100 degrees c on the newer ones. This will give a 15 degree temp difference.
So a reading of 15 degrees is actually 30.
only problem with this is i contacted asus and they said to RMA the board that it was faulty i emailed them back with the googled evidence and am waiting for a reply. Also checked the Cpu support on their website and the e6550 is supported.
I will see what they say. If anybody else has seen anything like this let me know
Panasonic TX32LXD700, Panasonic DMR EX-77, Onkyo 605, KEF 3005 5.1 Surround Speakers, HTPC (Blu-ray), Wii
