AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Motherboards, CPUs, Cases and PSUs
LinkBack Thread Tools Display Modes
Old 24-11-2007, 4:07 PM   #1 (permalink)
600w Psu ?
Hi im getting a new PSU for the ATI 3870 (Powercolor PCS version), and im wondering which one to get?
I HAVE A BUDGET, so, you know i dont need SLI, Turbo charged neon light versions.
1), Is the company EZ Cool any good, and 2), how many amps on the +12v rail should i be looking for? Ive got a core 2 duo system, 1gb ram, 1 IDE 80gb hard drive, getting a sata 200gb drive and 2 case fans i guess are the most basics.
thanks in advance,lizz.
hellknight_lizz is offline
Old 26-11-2007, 9:54 AM   #2 (permalink)
mjn
Thanks: Gave 91, Got 332
Re: 600w Psu ?
I've never heard of EZ Cool, but it sounds like something you'd find on Ebay.
You can't go wrong with PSU's from Tagan, Seasonic, or FSP.
Sony STRDB930, Rotel RMB-1075, Arcam DV-89, Sony KDL-40X2000U, HD HTPC, B&W CDM 1NT, CNT & SNT, MF A3 24-bit DAC, 460gb TiVo, SkyHD, TSU7000 ProntoPro NG, QED cables
Follow my PC Case mod project here: http://www.hardforum.com/showthread.php?t=1189553
mjn is offline
Old 26-11-2007, 3:19 PM   #3 (permalink)
miketrim's Avatar
Thanks: Gave 0, Got 7
Re: 600w Psu ?
I recently had two EZCOOL psu's from Scan and both went bang. I would spend a bit more and save yourself the hassle I had. how much do you want to spend?
miketrim is offline
Old 26-11-2007, 11:20 PM   #4 (permalink)
wormvortex's Avatar
Thanks: Gave 28, Got 80
Re: 600w Psu ?
My PSU has 24A on the 12v rail (I think) though it does have 4 separate ones
The one with the most albums when you die, wins
wormvortex is offline
Old 28-11-2007, 2:11 AM   #5 (permalink)
Thanks: Gave 2, Got 28
Re: 600w Psu ?
hi
http://www.overclockers.co.uk/showpr...id=123&subcat=
the above psu above should see you through , the 3870 is not so power hungary as nvidias crop , but i would shop around and save some ££££'s
C2D E8400 3 gig @ stock --Zalman 9700 cooler --ATI 4870 -- 2gb corsair pc6400 ram -- Gigabyte DS5-x38 -- 550W+ psu -- Win xp pro .
Dragy2k is offline
Old 18-12-2007, 5:20 PM   #6 (permalink)
Re: 600w Psu ?
Hmm, i was woried about cheaper psu's blowing /damaging my pc, so i guess it does cost more but your safer.
http://www.scan.co.uk/Products/Produ...oductID=408083
My budget is around £40, max about £50. Im ordering after xmas hopefully people will be having sales ect, i noticed the shops have booted the prices up, the 3870s meant to retail at about 140, and the 8800GT i found on google shopping for £250 so thats a bit crappy. Oh im definatly getting the 3870, cos i only have a 4x pci-e slot (dnt worry other people said it runs fine), but nvidia gets bottlenecked by slot speed horrendously. ATI dosent. simple as really.
anyway back to PSU's, the 3870 needs a "450w" or higher psu , i dont need one with SLI/2 gpu connections, and i think that the hiperpower one fits the bill. Its partnered with Nvidia and intel and AMD, so surely it must be a reliable company.
The only thing im scared of is the +12v rail thing, does the amperage get added together, (in this case 35amps) or is one rail for one card, ARGH this is annoying.
Heh, i talk to much, see if you can answer that then :P
Old 18-12-2007, 10:09 PM   #7 (permalink)
booyaka's Avatar
Thanks: Gave 60, Got 332
Re: 600w Psu ?
hiper psu's don't have the best of reps but they are ok.
I would check your motherboard firstly as i'm fairly sure that the 3870's still need a x 16 pci-e lane.
otherwise your budget is a bit tight for a good psu.
The corsair range come highly recommended.
best one is the corsair 520W HX but @ £62 it's a bit over budget.
Otherwise check out
http://www.ebuyer.com/product/131052...roduct_reviews
Corsair VX450WUK 450W PSU
BAsically they are rebadged seasonics which you can't go wrong with.
Q6600 @ 3.37ghz (prime stable 8hrs) 4gb Ram, Gigabyte P35C-DS3R, Antec 900 and 8800GT (all watercooled!)
Nikon D40, 18-55mm and 70-300mm VR
booyaka is offline
Old 19-12-2007, 4:13 AM   #8 (permalink)
james.miller's Avatar
Thanks: Gave 6, Got 124
Re: 600w Psu ?
Otherwise check out
the Hx series are built by seasonic. the VX series are channelwell (CWT) and perform pretty much the same, though im not convinced by the build of them, as quite a few of the reviews have pointed out. they dont seem to be screwed together quiet as well.
the psu is the heart of a system. do not skimp on it. by a decent brand only, from the likes of seasonic, pc p&c, corsair, the new enermax units ect. and unless you are intending to run a top end single card liek an 8800gts/gtx or sli, you dont even need a 500W PSU.
I had an entire pc based around a 3.3ghz e6600 c2d and an 8800gtx, and it pulled <400w from the mains and that included the draw of the monitor (22" dell TFT). when you work it out, the actual draw of the components was less than 300watts. yes, thats with an 8800gtx!
BS, where did you hear that. the difference is minimal.
Sony VAIO fw-11s w/ 320gb WD Black hard drive
ONKYO TX-SR805, mission m71i's, panasonic th-50pz80b
ps3: cant remember atm 360 gamertag: JimmyDonWon
james.miller is offline
Old 19-12-2007, 7:55 PM   #9 (permalink)
Re: 600w Psu ?
The thing about cards being bottlenecked by pci e speed? It was a benchmark i saw somewhere, the results put me off nvidia in a 4x lane...i'll go dig it up might take a few mins ^^
Old 20-12-2007, 9:06 AM   #10 (permalink)
mjn
Re: 600w Psu ?
Why would you be putting a PCI-e VGA card in a 4x slot? When all motherboards with PCI-e, have at least one 16x slot.
mjn is offline
Old 20-12-2007, 7:51 PM   #11 (permalink)
Re: 600w Psu ?
Is a 775-dual vsta by asrock, these clever little things have agp and pci-e at the cost of only a 4x pci e slot. Dont worry on other sites people have said the card itself works, but i just need a new psu to power it at the moment.
600w, psu
Refbacks are On
Thread Thread Starter Forum Replies Last Post
For Sale : Braun Multiquick Professional 600W Turbo Hand Processor and MUCH more tianuk Archive : Completed Business and Expired Threads 1 04-05-2007 5:18 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
