AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Motherboards, CPUs, Cases and PSUs
LinkBack Thread Tools Display Modes
Old 20-11-2007, 11:54 PM   #1 (permalink)
Thanks: Gave 3, Got 0
Do you really need thermal paste when instaling a cpu?
Sorry for the simpleton question, but I'm building a system(still havent got a graphics card as Im waiting for 88gt stock). Anyway I've got an E2140 CPU and am wondering if I have messed up by instaling it with just the sort of gel bit that is stuck on the stock cooler.
ghostofmaxwell is offline
Old 21-11-2007, 12:00 AM   #2 (permalink)
Uridium's Avatar
Thanks: Gave 85, Got 533
Re: Do you really need thermal paste when instaling a cpu?
Nah that'll be fine. Most people balls it up by smearing to much gunk on anyway
PSN - Uridium_UK
Uridium is offline
ghostofmaxwell (21-11-2007)
Old 21-11-2007, 12:00 AM   #3 (permalink)
That little gel bit is the thermal paste. It will melt once you installed the cpu and turn on the power. It's all you need.
LittleBlueDot is offline
Old 21-11-2007, 12:04 AM   #4 (permalink)
Badger0-0's Avatar
Thanks: Gave 69, Got 793
No you don't at standard spec.
But would you really risk a £60ish plus processor for a couple of quid?
If you're tweaking, it's a no-brainer, IMO.
I don't tweak, but wouldn't consider fitting even a standard chip without thermal paste, FWIW.
ASTON VILLA
I don't know what I'm supposed to think, so I guess I'll have to make my own mind up.
Badger0-0 is offline
Old 21-11-2007, 12:04 AM   #5 (permalink)
Yeah I kind of thought that was the case. Thanks you guys
Old 21-11-2007, 12:08 AM   #6 (permalink)
Yeah because I've got an Nforce board aswell, so Im planning to overclock as the entery level dual core is apparently a great overclocker...
Hmmm now Im stuck between a rock and a hard place I think.
Old 21-11-2007, 12:31 AM   #7 (permalink)
Badger0-0's Avatar
Well, I have to hold my hands up and say I'm 5 years out of date
The younger (I guess) lads are saying you don't need it.
They probably know better than me, in all honesty
But I'd still be tempted to pay the extra few quid.
I know you're looking to cut corners (aren't we all?) but I can't see the point in scrimping here.
Having said that, from the little I know, it has to be done right.
And as has been said, you can put too much on.
The top paste sellers have pages that expand on this, so you should read carefully, IMO
ASTON VILLA
Old 21-11-2007, 12:40 AM   #8 (permalink)
You thought I would have learned by now not to be so hasty.
Do you think It will damage the cpu if I remove it now and paste it up? I havent fired it up yet as I dont have the graphics card .
Old 21-11-2007, 12:33 PM   #9 (permalink)
Thanks: Gave 6, Got 310
The coolers I have seen recently all have thermal paste preinstalled onto the cooler. I have just bought (but am yet to install) a new system and have the Artic Cooler pro 7. This has the paste and there is no advantage (stated in reviews of this cooler) to add Artic Silver etc. But if you do then you need to carefully remove the paste already on the cooler. If already installed then also clean the CPU.
The only reason IMO for adding paste is if you remove and reinstall the cooler.
Mark.
Lexicon MC-8B. L/C/R: Blue Sky 6.5's, SL/SR/SBL/SBR: Blue Sky 5's, Sub: Velodyne DD-15
Panasonic NV-HS830, VTX-D800U via TiVo, Arcam DV29 & Sony BDP-S500 > Lumagen VisionHDP > Panasonic TH-46PZ85B. Marantz RC9200
MarkE19 is offline
Old 21-11-2007, 1:10 PM   #10 (permalink)
Yeah my cooler had 2 or 3 stips of what I can only describe as ''stickers of a gel substance''.
I think I will leave it as it is. Maybe I will get a 3rd party cooler if I cant overclock well, then think about extra paste.
Old 22-11-2007, 1:05 PM   #11 (permalink)
Thanks: Gave 43, Got 173
I think the OP is referring to adding the paste to a new CPU/fan that already has the gel pad on it rather than in general.
At least, thats how i read it.
Dave
Gallery@
http://davepearce.smugmug.com
Canon 40D | 17-55IS F/2.8 | 24-105L F/4 IS | 35mm F/2 |50mm F/1.4 | 85mm F/1.8
dave_bass5 is offline
Old 22-11-2007, 2:26 PM   #12 (permalink)
oh yes
tiredeyes69 is offline
Old 23-11-2007, 11:07 PM   #13 (permalink)
SeanT's Avatar
Thanks: Gave 62, Got 217
If the preinstalled stuff is on the chip / cooler, it works better than the paste, as it fills the gaps better - otherwise a thin smear of thermal paste is a good idea, just don't put too much on, it's only to fill the imperfections between the processor heat dissipating surface and the "perfectly flat" heatsink base - in theory if you have perfect components you don't need it, but there will always be gaps, which create hotspots, which kills the chip...
Relysis 40 inch LCD, Harman Kardon AVR 630, MCPC (CM260, IMON, Tosh HDDVD-ROM, E2200@2.75GHz, 2400XT, 2GB, 320GB, Sweetspot SDI card,Happauge HVR4000, MCE'05), Kef XQ5/XQ2C/Q2DS/Q8S, Cyrus aca7.5, PSXR, CD6, Quad 303 x 3, Sky+ 250 SDI
SeanT is offline
cpu, instaling, paste, thermal
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Wanted : Thermal paste pad or syringe Ayub Archive : Completed Business and Expired Threads 3 19-08-2007 4:33 PM
Question about cpu fan and thermal paste JamieMc88 Motherboards, CPUs, Cases and PSUs 3 01-03-2007 1:53 PM
Thermal paste stevomacca Computer Systems 5 15-09-2006 3:06 PM
Removing thermal paste? Melkor PC Games 10 05-06-2006 8:00 PM
Thermal paste on Athlon 64's Uridium PC Games 23 18-03-2006 4:41 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
