AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Motherboards, CPUs, Cases and PSUs
LinkBack Thread Tools Display Modes
Old 20-11-2007, 11:31 PM   #1 (permalink)
Thanks: Gave 3, Got 4
Compatible motherboard for Nvidia 7300GS and X-Fi Extreme Audio
Hi all,
I bought a Nvidia 7300GS low profile 256MB graphics card off someone in the forums, but didn't actually give much thought to compatibility
I think the current motherboard I have is a mini AGP (Fairly sure-ish), and is close to a few thousand years old.
I'm under the impression that I need a PCI-Express compliant motherboard with a full size expansion slot in order to accommodate the graphics card (Although I honestly have no idea).
In addition to this, I am looking at getting an X-Fi Extreme Audio sound card which also needs to be added to the mix.
The catch is that it has to fit into a space no bigger than 22cmx19cm (the size of the current motherboard).
The question is... can it be done?
Jonesybones is offline
Old 21-11-2007, 11:33 AM   #2 (permalink)
Thanks: Gave 1, Got 1
Re: Compatible motherboard for Nvidia 7300GS and X-Fi Extreme Audio
Think your board is more of a micro ATX than AGP ( as AGP is a slot for graphics cards). ATX is the standard size motherboard, micro being a small version.
most micro atx motherboards are 244 by 244 ish, so you will be struggling to find one smaller...
yoyo tech has one here http://www.yoyotech.co.uk/product_in...6e0d05b0544389 the size is 9.6"(244mm) by 7.2"(182mm).
it has a PCI express slot for the graphics card, and a PCI slot for the sound card.
depending on what you have at the moment, it may mean a processor upgrade and a ram upgrade. You may be worth selling the graphics card and trying to find a AGP version.
droitwichdos is offline
Old 21-11-2007, 4:36 PM   #3 (permalink)
Oops, thanks mate - meant ATX (I think my brain is slowly leaking out).
I took the thing to peices last night and with some jiggery pokery and a sprinkle of magic I might be able fit a bigger motherboard in...
I reckon I now have 22cm (maybe 24 with a squeeze) by 30cm of space to work with.
The only question I now have is whether or not I can find a micro atx board that's compatible with my cpu and ram...
7300gs, audio, compatible, extreme, motherboard, nvidia, xfi
Refbacks are On
Thread Thread Starter Forum Replies Last Post
For Sale : UK: Asus Striker Extreme nForce 680i SLi motherboard. kup Archive : Completed Business and Expired Threads 11 20-10-2007 6:26 PM
WTD:3700+ or above cpu and compatible agp motherboard diggler46 Archive : Completed Business and Expired Threads 9 03-11-2006 10:41 PM
help - what motherboard needs to be viiv compatible hddvdman Motherboards, CPUs, Cases and PSUs 2 31-08-2006 12:44 PM
Nvidia 7300GS Stu_B Windows Media Center Edition MCE 3 31-03-2006 8:29 PM
Skystar 2 not compatible with NVIDIA chipset Rob Jarvis Computer Systems 0 31-12-2005 7:47 PM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
