AVForums.com is the UK's biggest & best home consumer electronics discussion resource New to AVForums.com? Start by reading our introduction here.
Go Back   AVForums.com > Computers > Motherboards, CPUs, Cases and PSUs
LinkBack Thread Tools Display Modes
Old 20-11-2007, 10:32 PM   #1 (permalink)
Uridium's Avatar
Thanks: Gave 85, Got 533
Antec 900 case owners please read
My Gaming machine uses a Antec 900 case, fantastic case that it is I'm struggling to keep the dust out!
I've got a couple of akasa filters on the 2x 120mm front fans but just can't seem to find a filter for the 200mm monster on the top.
Has anyone else managed to filter their top fan?
thanks
PSN - Uridium_UK
Uridium is offline
Old 21-11-2007, 1:34 AM   #2 (permalink)
Thanks: Gave 2, Got 28
Re: Antec 900 case owners please read
cant you d.i.y it using materials like tights/stockings streached over a homemade type cradle..i was thinking of getting the antec 900 but dust does seem a problem.
look for materials that are similar to the dust filters on the front 120mm's....let us know how u get on im 100% sure it can be fixed by d.i.y ..good luck !
C2D E8400 3 gig @ stock --Zalman 9700 cooler --ATI 4870 -- 2gb corsair pc6400 ram -- Gigabyte DS5-x38 -- 550W+ psu -- Win xp pro .
Dragy2k is offline
Old 21-11-2007, 9:22 AM   #3 (permalink)
Uridium's Avatar
I took a 2nd look at the case last night and i think the best DIY solution would be one of those cartridge style HEPA filters you get for bagless vacuum cleaners. I think one of these will fit inside the case underneath the fan as there is a bit of space inside the top.
really is a superb case though....If you want to run a high spec gaming machine on air nothing keeps it cool like one of these cases
PSN - Uridium_UK
Uridium is offline
Old 21-11-2007, 10:04 AM   #4 (permalink)
Uridium's Avatar
Looks like the 200mm fan is actually just an exhaust fan so you don't need a filter on that one.
So hopefully just the 2x Akasa 120mm filters should do the trick
http://www.antec.com/uk/productDetails.php?ProdID=08009
PSN - Uridium_UK
Uridium is offline
Old 21-11-2007, 4:02 PM   #5 (permalink)
yeah it is an exhaust fan but if your still getting a dust problem streching a bit of old tight's over it may cure it while allowing your airflow to continue unhindered.....gl
Dragy2k is offline
900, antec, case, owners, read
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Help needed from all Antec Fusion case owners atothej Computer Systems 3 26-09-2007 8:10 AM
Antec Fusion V2 case IR ? Graham Sims Windows Media Center Edition MCE 0 29-07-2007 4:50 PM
Anyone with an Antec 900 Gaming case? Uridium Motherboards, CPUs, Cases and PSUs 0 16-07-2007 10:50 AM
Antec Fusion Case where to buy? scott8629 Computer Systems 2 06-02-2007 9:07 AM
AV ForumsOptimised for Firefox.
Copyright © 2000-2008 M2N E. & O. E.
