13-11-2007, 2:20 PM
#1 (permalink)
Thanks: Gave 17, Got 12
Overclocking help please
I've got a Core 2 Extreme 2.66Ghz connected to an ASUS P5N32-E SLI Motherboard.
I was wanting to overclock the CPU to say something like 2.88Ghz just to see how much difference there would be.
However, it's not quite as simple and a bit more jargon clogged than I though it would be. I notice in the bios settings on this motherboard there's an Extreme Tweaker. I was expecting to just type in 2.8 somewhere and that would be that.
Can anyone help me out here. Cheers in advance.
Samsung 42Q97HDX - Toshiba 32WLT66 - XBox 360 Halo 3 Ed - PS3 40gb - Nintendo Wii - PC 'Dell XPS 630' Core 2 Duo E8500 @ 3.16Ghz with 4 GB RAM and 2x 8800GT 512mb SLI, BluRay Drive, Samsung 22" SycMaster
13-11-2007, 2:29 PM
#2 (permalink)
Thanks: Gave 91, Got 332
Re: Overclocking help please
You need to alter the FSB of the CPU, you may also have to upgrade your CPU cooler, depending on what you currently use.
You may also have to alter the voltages to the CPU and memory, depending on what else you change, such as memory mhz and ratio, FSB and frequency of the CPU. Although the frequency is locked on most CPU's now. You used to be able to use a pencil to unlock this in the olden days!
Sony STRDB930, Rotel RMB-1075, Arcam DV-89, Sony KDL-40X2000U, HD HTPC, B&W CDM 1NT, CNT & SNT, MF A3 24-bit DAC, 460gb TiVo, SkyHD, TSU7000 ProntoPro NG, QED cables
Follow my PC Case mod project here: http://www.hardforum.com/showthread.php?t=1189553
13-11-2007, 2:34 PM
#3 (permalink)
Hmm, I think I'm just going to chicken out of this then.
13-11-2007, 2:52 PM
#4 (permalink)
Thanks: Gave 404, Got 786
Up your FSB to 333, make sure your memory is running at the correct speeds and voltage (see manufacturers website for details). Also you may need to up your vcore a little. If its a dual core I would say 1.4v would be about right for a FSB of 333.
Click for AV Pics & Spec
70" 1080p SXRD & Watercooled Quad Core HTPC - Pio AX4ASi-S, Sky HD, 360 Elite, 360 Prem, PS3, Bose AM15, NevoSL Games PC 24" Dell 2407 A04, Asus P5K Premium, Q6600Go@3.0Ghz, 4Gb 1066Mhz, 8800GTX, 620W Corsair, Thermalright 120 Ultra Ex, Akasa Eclipse, X-fi, MX Rev, Vista
13-11-2007, 2:56 PM
#5 (permalink)
Thanks: Gave 60, Got 332
also remember that with the extreme cpu's you can increase the multiplier as that is unlocked.
as mentioned above - to increase very slightly the overall speed, you should probably be ok just to increase the FSB a little bit and this should bump your speed without messing around with the voltages etc.
However, i would advise you to read a overclocking guide like
http://forums.overclockers.co.uk/sho...php?t=17612922
to understand the basics.
Q6600 @ 3.37ghz (prime stable 8hrs) 4gb Ram, Gigabyte P35C-DS3R, Antec 900 and 8800GT (all watercooled!)
Nikon D40, 18-55mm and 70-300mm VR
13-11-2007, 3:00 PM
#6 (permalink)
Cheers Razor,
I've no idea what you're talking about but I'll look into it the next time I restart my PC. Now when you say to make sure my memory is running at the correct speed and voltage is that relative to if the FSB was 333?
Cheers again
Thanks Booyaka,
I'll check it out.
13-11-2007, 3:22 PM
#7 (permalink)
Okay, now I'm worried.
I've had to move to my girlfriends laptop. All I did was increase the CPU multiplier in the Extreme Tweaker from the bios settings from 10 to 20 saved and exited now my PC does nothing. It switches on but nothing else happens. No boot up screen, mouse and keyboard don't light up. What can I do?
13-11-2007, 3:24 PM
#8 (permalink)
You need to reset the BIOS. In future, adjust the CPU properties manually, and not use the set profiles.
13-11-2007, 3:24 PM
#9 (permalink)
Originally Posted by caz2005
Cheers Razor,
Cheers again
Thanks Booyaka,
I'll check it out.
If you have DDR2 memory and its rated at 8800MHz @ 4-4-4-12
Make sure it is set like this in your Bios. Also make a note of the correct voltage as most mobos are set at 1.8v for the memory which is too low of most decent DDR2. Most are set between 2.0v and 2.3v. Mine are running at 2.2v
You can use a program called cpuz to check your system settings. It will show up as 400Mhz in cpuz this is correct for 800MHz DDR2.
2 x 400Mhz = 800Mhz.
13-11-2007, 3:24 PM
#10 (permalink)
Or sometimes, you can press the Insert key while powering on to reset the CPU settings.
13-11-2007, 3:25 PM
#11 (permalink)
But I can't do anything. Nothing comes up on my monitor and my keyboard is non functional.
13-11-2007, 3:37 PM
#12 (permalink)
Ouch you changed the multiplier from 10 to 20. Thats double.
I dont know much about laptops in terms of clearing the cmos. But this is what you need to do if it was a desktop so I am guessing the same principals apply here.
13-11-2007, 3:39 PM
#13 (permalink)
No no, I'm just using a laptop while my PC is unoperable. I figured 20 wouldn't be so high as the maximm was 50.
Anyone know how I can get my PC functioning again so I can reset the bios settings?
13-11-2007, 3:44 PM
#14 (permalink)
Clear the CMOS.
13-11-2007, 3:45 PM
#15 (permalink)
Sorry for my iggnorance but I don't know how to do that.
Okay, I've just googled it but I need the functionality of my keyboard to do it which I aint got.
