07-11-2007, 5:00 PM
#1 (permalink)
asus p5k speaker {the beeps}
hi, am just putting together a system which includes p5k motherboard , can anyone tell me if it comes with a system warning speaker {the beeps } i cant find it any where ,the connections are on the mb ,but no speaker? is it onboard or does it come with your pc case ,
thankyou for any help ...sean
asus p5k motherboard.
07-11-2007, 5:09 PM
#2 (permalink)
Thanks: Gave 404, Got 786
Re: asus p5k speaker {the beeps}
I have a P5K Premium (the top end P5K) and I have connected it up to my case speaker. So I am guessing the answer is no. Have a look at the Asus website for product info and specs.
Click for AV Pics & Spec
70" 1080p SXRD & Watercooled Quad Core HTPC - Pio AX4ASi-S, Sky HD, 360 Elite, 360 Prem, PS3, Bose AM15, NevoSL Games PC 24" Dell 2407 A04, Asus P5K Premium, Q6600Go@3.0Ghz, 4Gb 1066Mhz, 8800GTX, 620W Corsair, Thermalright 120 Ultra Ex, Akasa Eclipse, X-fi, MX Rev, Vista
07-11-2007, 5:32 PM
#3 (permalink)
thanks i have the coolermaster cm690 case cant find any system warning speaker ,,  can you use speaker from another board or buy one ,,thanks
07-11-2007, 5:37 PM
#4 (permalink)
All you need is a small speaker with 2 pin connector to connect up to your mobo. I am sure you can find such a thing on ebay or a good pc supplier.
